How can I tell what's broken?
Discussion in 'Modifications & DIY how-to' started by SubiNoobi, Feb 7, 2010.
  1. SubiNoobi
    SubiNoobi Supporting Member
    I just took apart two EJ20 blocks and have all the parts sitting in my garage. I picked up the blocks for free, so I'm not expecting much. However, it would be nice if I ended up with some useful parts.
    What I have is two blocks minus one set of pistons. That is:
    2 sets of block halves.
    2 sets of 4 rods
    2 cranks
    1 set of 4 pistons
    This is what I see so far: Piston walls "look" good (not that I could tell just by looking). Below the chambers, there are some places that have been scored by the crank - on both blocks.
    Don't really know how to check the status of the bearings, and I think I am missing some from the block that was missing pistons.
    What should I look for to determine if anything is of use? I can take pics or take the parts to a pro and get them assessed.
    Right now I have no particular plans for all of this stuff, but that may change depending on what I can do with all of it.
    Thanks!
  2. Mike@TTR
    Mike@TTR Active Member
    Take measurements :) Check against factory tolerances.
  3. b reel
    best thing to do is take the halves and cranks to a machine shop to have those tolerances checked. Most people don't have the proper calipers to check the cylinder bores
  4. integroid
    I agree with breel. Ball Engines can do it for you.
  5. SubiNoobi
    Thanks guys, that sounds good.
  6. b reel
    After you mic out the cylinder bores take one shortblock to Mark at SOG and sell it to him. I don't think his block will have a enough metal to go 20 over and a hone. He has some really scored cylinder walls on his 2.0L
  7. Cool_____
    You have to keep the two block halves together also fyi. You can't mix match halves.
  8. Kokopelli
    I have 2.0 block halves in great shape if Mark needs any.
  9. Kokopelli
    I even have an extra set of sti rods.
  10. SubiNoobi
    Thanks for the advice guys. These parts are still just sitting in the garage, though. I'll take a more serious look at it after I blow a bunch of money on my trip to Bavaria!
    I'll look into STi rods and other parts as needed once I find out what's broken. I do know that I'll need some heads.
  11. Jake
    one of those blocks is mike's (kokopelli) and the other came from bobby's car. if that helps
