how long does suspension last?
Discussion in 'Modifications & DIY how-to' started by 7wolf, Mar 6, 2007.
  1. 7wolf
    7wolf Member
    May 28, 2005
    248
    0
    i got my tien coilovers in 04 and now when i go over the speed bumps in my subdivision they make noise. i was wondering if i have to replace or rebuild the struts and if i ever have to do anything with the springs. anyone know?
  2. miloman
    Feb 3, 2004
    12,774
    1
    overtime, the struts will need to be revalved but the springs should be fine... go to SOG and have either SS or WJM drive it and they should be able to direct you accordingly
  3. 7wolf
    7wolf Member
    May 28, 2005
    248
    0
    thanks man
  4. slowwrx
    Supporting Member
    Mar 8, 2005
    4,343
    1
    You are probally due for a rebuild, I think the suggested interval for Teins is 15k miles. But I'm not sure. The rebuild isn't to expensive.
  5. clemsonscooby
    clemsonscooby Active Member
    Dec 13, 2005
    1,536
    0
    How do you know its the coilovers? A lot of suspension noises are from swaybars. Is it a squeek, clunk, or rattle?
  6. Strayen
    Strayen Active Member
    Oct 17, 2006
    1,041
    0
    man my car squeaks when it's cold out and then slowly goes away.....I think it's my sway bars perhaps? I used decent amount of the Mobil F1 red gook.
  7. jayj713
    jayj713 Member
    Feb 13, 2006
    827
    0
    my suspension squeaks whenever i go over really severe speedbumps that i have to take going at like <1mph. It's like a really really old matress squeak i think.
  8. clemsonscooby
    Dec 13, 2005
    1,536
    0
    Definitely swaybar. Those Teins should last 30k before revalving unless you are tracking every month. Check out the bushings, they may need some more Li grease.
  9. miloman
    Feb 3, 2004
    12,774
    1
    personally i'd expect bad roads to take a greater toll on coilovers than a nice smooth track surface
  10. clemsonscooby
    Dec 13, 2005
    1,536
    0
    Thats a good point, but the dampening is always set much higher when on the track. The soft street dampening should allow the strut to move a lot more and sustain the bumps better.
  11. 7wolf
    7wolf Member
    May 28, 2005
    248
    0
    i guess it could be the sways, the more the bounce the more the squeek. i just didn't think i had that many miles on them to need a rebuild but i didn't know.
  12. keeganxt
    keeganxt Active Member
    Nov 13, 2006
    1,071
    0
    Anyone know the price of a rebuild for teins, JIC, etc...
  13. pEd
    Mar 5, 2004
    2,460
    3
    I think (the last time I looked into it) the Teins were about $150/each to rebuild.
