How much boost...
Discussion in 'Modifications & DIY how-to' started by jonnyboy0150, Jun 28, 2006.
  1. jonnyboy0150
    jonnyboy0150 Member
    How much boost will a Greddy Type-S blow off valve hold before leaking?? Im looking to change bov's due to hood clearance issues.
  2. Weapon
    heck for a $200 bov it better be able to hold atleast 25lbs of boost if not more..i tried diggin up some info but nothing specifies what it maxes at..this is about as much info as I was able to find about the type S "The spring stiffness adjustment screw and the two different sizes give the GReddy user the option to match vehicles with mild upgrades to heavily tuned engines." The Greddy RS also looks pretty sharp. And a few sites I thumbed through recommended it over the Type S.
    here is a link from a EVO site with a small vid of the Type RS
    http://forums.evolutionm.net/showthread.php?p=1461688#post1461688
  3. jt money
    funny when i looked it up i was at the same sight. i had problems finding out the max psi also.
  4. jonnyboy0150
    jonnyboy0150 Member
    True, lol. Thanks for the help guys, Im gonna pick the bov up today and see how it does.
  5. goixiz
    goixiz Active Member
    If anyone need s to calibrate any thing for pressure less than 80 psi with 0.1 psi accuracy let me know - I have some toys that can do that.
