Hows this look ( datalogg)
Discussion in 'Modifications & DIY how-to' started by emstraumajunke, Nov 19, 2006.
  1. moose
    Looks like you've been sitting idling and barely blipping the throttle :) I'm guessing you have the resistor mod replacing the uppipe EGT sensor, so just turn that off since it won't change. I'd also disable:
    a/f current (amps)
    a/f current (mA)
    Fuel pump duty
    Convert the air/fuel from Lambda to AFR (should be an option), and find your ignition advance multiplier since that'll be a good indicator of detonation.
    And convert KPH to MPH. :)
  2. jonnyboy0150
    jonnyboy0150 Member
    I noticed the resistor mod for the EGT sensor as well, lol!
  3. Kokopelli
    What em do you have and who tuned it?
  4. Accessport its my old tune before the sti block
  5. crashtke
    I am not sure which EM you have but TPS and knock events are always good things to monitor.
  6. crashtke
    Do you have Street tuner?
  7. Alex
    Sorry about that Ivan, I passed out after dinner. Glad to see you got these online.
