i know this has been asked before but...
Discussion in 'Modifications & DIY how-to' started by crash#2, Sep 22, 2006.
  1. crash#2
    crash#2 Member
    can i fit a 225 50 16 on the stock wheel? or is the biggest size for stock 215 55 16
  2. Deke
    Deke Active Member
    Yeah, you can.
  3. crash#2
    crash#2 Member
    YEEEEEEEEEEEEEEEEESSSSSSSSSSSSSSS!!!!!!!!!!!!!
    thank you buddy!
  4. Deke
    Deke Active Member
    Haha no prob, yeah I just went out to verify, and that's the size that I have on mine.
  5. Galimore
    Galimore Member
    Is this true for the stock '05 wheels too? Looking to order some new tires here too :)
  6. josh booth
    josh booth Active Member
    Yes you can. But it is pointless the tire will only be as wide as the wheel.
  7. gte123v
    gte123v Member
    I don't think that's true. pretty sure a single size wheel can support multiple different sized tires, and the actual tread width is the tire's width, not the wheel.
  8. Galimore
    Galimore Member
    Thanks all -- I'm sure whatever I get will look better than the RE92's...as long as there's no scrubbing. I'm curious how much of a weight difference there is between a 205/55/R16 and a similar 225/50/R16 tire. I'll keep looking around, surely it wouldn't be enough to have a significant impact. Thanks!
  9. the more oversize the tire, the more roll you will have from the sidewalls.
    plus, its not like we need more acceleration grip, right?
  10. goixiz
    goixiz Active Member
    you can but its not optimum
    225 is optimized if using 7.5" rim
    for 6.5" rim I personally wont go hiogher than 215s
  11. clemsonscooby
    clemsonscooby Active Member
    Going to the larger tire on a 6.5" will not make the car "look better" if that is what you are going for. It may slightly improve the handling over the 215, but not worth the price difference. If this was going to be a 225 race tire, I would definitely suggest it, because the sidewalls are really stiff.
  12. Galimore
    Galimore Member
    Thanks for the replies :)
    Yea I want to get some Falken Azenis RT-615 and the only sizes are 225/50R16, 215/45R16, and 205/40R16. According to their chart the 225/50's are compatible with wheels from 6"-8"
    http://www.falkentire.com/rt615_sizes.html
    So these should be fine??
    Also on a side note....which I should make a new post for but I'll throw it out:
    I've heard Azenis average around 7K miles...I want them for monthly AutoX's but only have one set of wheels so they would also be my daily tires (400 miles/week all over Atlanta). Waste of money?? Can anyone recommend an alternative that is equally agressive but a little more road-oriented? Thanks!!
