I need good exhaust work please.
Discussion in 'General Community' started by Bolderer, Jan 11, 2007.
  1. Bolderer
    Bolderer Member
    I need a custom mid pipe made and I need to know who can be trusted for custom exhaust work. Preferably intown cause I'm a L5P area resident. I know a lot of you guys live OTP and I'm just not driving 45 minutes + for exhaust work. Thanks for all the suggestions.
  2. calmnothing
    If you want good quality you can try Mainstream Performance and Turbo Dave. Some of the best custom welding I've ever seen. They're like 45 min from you tho. Most Midas's and such can do them but most likely it'll be cheap aluminum piping instead of stainless steel.
  3. Weapon
    45 minutes is nothing..you could always order a new one online or check ebay. I have seen them as low as $80 and no higher than $145 for a new one. Then you could swap it in and out when ever you wanted to.
  4. Alex_ATL
    Alex_ATL Member
    my friend Kenny will do you some good work... if Covington is anywhere near you (exit 90 off highway I-20) tell him Alex with the maxima sent you over
  5. Goose013
    Goose013 Member
    45min is nothing for good custom work....besides it's 30min to anywhere in Atlanta :)
  6. Alex
    Good luck on the search!
  7. Bolderer
    Bolderer Member
    Thanks for the input guys.
  8. Alex
    There's a Midas on Northside / 14th St...
  9. Weapon
    crush bend FTW!
  10. Slowsoul
    Slowsoul Member
    Grand Muffler....period
  11. slowwrx
    Grand Muffler is no longer owned by Buster, I can not attest to the quality of the work performed by the new people, Turbo Dave does nice exhaust work.
  12. Slowsoul
    Slowsoul Member
    Well, I can...
    The new guys did the custom work on my 89 4runner 3.4 swap and a custom resonator install on the ANSA Silverline that was previously on my 02 WRX.
    The new guys are good.
  13. Bolderer
    Bolderer Member
    Well Marc, I ended up taking your advice and going with Grand Muffler. They did a fantastic job and were really nice guys. The owner, Todd, even let me drive his supped up Mercury Marauder. He was just like "the keys are on the counter, take her for a spin." I said "uuuuuugh OK." It was pretty fast for 4500 pounds of car. Anyways, thanks again for the referral, I will now happily pass it on. See ya round.
  14. JJang12
    JJang12 Active Member
    so what kind of custom midpipe did you get??
  15. Bolderer
    Bolderer Member
    I have an SPT cat-back, which is 3" but made to mate up to the stock downpipe which is 2.5" so it has a reducer section. I also have a Helix DP which is 3" so I had to have the reducer chopped out and a piece of 3" pipe welded in it's place so that my exhaust is now truly 3" all the way back. claro?
  16. slowwrx
    Good to know they are still doing good work.
    Matt
  17. JJang12
    icic That's the real similar set up that I used to have. I might have to fabricate new exhaust system for me as well. I currently has 3" DP taper down to 2.5" and 2.25" stock mid pipe, and then out to 2.5" prodrive axleback. What's the address to grand muffler?
    I woud like to get 3"-2.5" mid pipe with a resonator to quiet down the noise.
