I use IE on at least 4 computers that access this site and havent had a problem. Do you ahve your Privacy settings to clear all UN and passwords on exit?
Well this is a new issue. We'll need a little bit more information What URL(s) are you using to access the website? Are you able to duplicate your problem in other browsers including FireFox, Chrome and or Safari? Do you have any software installed that prevents cookies / security settings set too high in IE from your "late night browsing" ?
http://wrxatlanta.com Firefox happens the same. Happens to me at work and at home. I have not change any setting in IE. It just started happening over the weekend. IWSTI had the same issue recently http://www.iwsti.com/forums/off-topic/197568-unable-stay-logged.html
I am making this post from the IE installed on my work laptop, running IE 8.0. I will re-visit the page and see what happens.
I've seen this same type of thing occur in Chrome and IE....but most typically when the "Remember Me" was not checked.
I have gone through our cookie settings I do not see anything that could be causing an issue. My next idea is for me to login under your account and see what happens. The problem is fairly simple and there are really only two possible answers: Either I broke something with the cookies or you have something on your end blocking our cookies ("c" below).
Haha, I'll be changing your password and logging in as you later tonight to see what I can reproduce/re-create.
Cool...had to log in again just now. My Nasioc, RS25, iwsti, and hotmilfs hsnono: jp!) username/passwords are all keep.
as a band aid fix, you can do the following in IE8 that might work. It has worked on other sites for me. 1. Go to tools and select Internet options. 2. Go to the privacy tab and select sites 3. In “Address of website:” box type in http://www.wrxatlanta.com and then click the “Allow” button. 4. Press ok, then apply, and then ok to close out the box.
I've been sitting logged in for an hour or so now without any logging out issues using IE8 (v8.0.7600). However, I did have to check the "Remember Me" box to remain logged. I was logged out on two occassions when I did not not select this box earlier this morning. FWIW, our cookie timeout is set to 900 seconds (15 minutes) of inactivity. Alex
Sure did, even replied to myself In all seriousness, no, I did not. Not my business what you do with your PMs :jb:
