Not sure if this is the correct location for this thread, but I have been having problems with the ignition fuse blowing out when the car is on. I'm thinking that there is a wire that is causing a short, but has anyone ever run into this problem that might have an idea where to check first, because there are a lot of wires under the dash. I thought I had found the problem, but it did it again. Right now it is running, but not sure if it might do it again. Any suggestion is appreciated.
Too many places. Make sure the wiring all around the coil packs is good and isn't grounding. Do you have a turbo timer? If so check all around those connections.
Ok sounds good. Yea I was going to take everything apart this weekend to check the wires. Do you think that the fan controller might have something to do with it also?
