Incredibly Basic QA
Discussion in 'Introduce Yourself' started by WRXCoupe, Feb 7, 2006.
  1. WRXCoupe
    WRXCoupe Active Member
    Hello All
    Here is a real basic and possibly dumbAis question but one that will keep me from breaking my vehicle. Where are the best jacking points for an 02 bugeye Sedan and where are the best spots to place jack stands. I am going to assume lower control arms for the jack stand but please correct me if necessary. Going jack and jack stand shopping this weekend then it will be brake pad and disc re-surface time.
    Thanks!
  2. Alex
    Generally, you can fit a jack on the stock jacking point (look for the break in the sideskirt) or on the inner portion of the subframe. It is also common to jack up on the jacking plate of the front diff (use a towel or something) and then put the stands either on the outside (sideskirt) or inside (subframe) depending on where you need to be on the car.
