Inspiration for 10th St JDM
Discussion in 'Modifications & DIY how-to' started by Cool_____, Apr 23, 2009.
  1. Cool_____
    The interior for the Gemballa Tornado
    And because people are gonna ask here is info on this car.
    GEMBALLA TORNADO 750 GTS -
    The new striking super sports car in SUV format
    There is only a little connection left between the GEMBALLA TORNADO 750 GTS and the Porsche Cayenne Turbo. At the most, the Porsche SUV is the master model for the latest development by the automobile manufacturer from Leonberg near Stuttgart. Already at first glance, the targeted goal of the technicians at GEMBALLA Automobiltechnik GmbH & Co. KG can be clearly defined: away from the SUV and more to an uncompromising sports car. The reason for the performed metamorphosis was the large amount of requests for a high performance sports car with the dimensions and the spacious interior of an SUV. 25 years of experience with innovative products based on Porsche sports cars contributed to the development of this new automobile. The unique signature of owner Uwe Gemballa is also clearly visible with the TORNADO 750 GTS: 750 hp and a vehicle weight reduced by 250 kg are only two unique selling points of this superb automobile. Once again, the company confirms its expertise when it comes to striking design and an especially powerful engine technology.
    Striking design for highest requirements
    In order to meet the sports car´s increased requirements in terms of light construction and torsional stiffness, Uwe Gemballa´s team optimised nearly the entire auto body. For this reason, the ultra-strength and especially light material carbon is mainly used. A front apron extended by 60 millimetres with integrated aero lip generates more downthrust at the front axle and in connection with the also extended rear section it renders the typical elongated sports car look. Extensive air inlets suck in additional fresh air for the engine, oil- and air intercooler; and moreover, an air duct system even brings the air to the front brakes. On the other hand, the engine heat is effectively diverted by air ducts in the also newly designed bonnet. The special highlight of the bonnet is its fusion with the front wings and the new, converse opening mechanism. Compared to the serial Cayenne, the one-part bonnet-wing-unit now opens forward and therefore allows a better access to the engine.
    The outstanding eye-catchers of the TORNADO flanks are the body extensions which are fitted all the way from the front to the rear. They make space for the extremely broad 12-inch rims and in connection with the new side skirts they render a dynamic look.
    The aerodynamics specialists also extensively optimised the rear section. The rear skirt has been extended by 40 millimetres and for additional downthrust, a race diffuser has been added. A rear spoiler with carbon flaps perfects the aerodynamic overall package.
    When designing the body kit, GEMBALLA does not leave any doubt that the TORNAGO 750 GTS is a full-blooded sports car. In order to emphasise this claim, GEMBALLA adds designer characteristics which are typical for sports cars: Round double tail lights and four end pipes of the high performance exhaust system which have been integrated in the rear skirt, confirm the powerful appearance.
    Extensive modifications at the driving gear render impressive results
    On the one hand, the combination of the sport exhaust system, the sport catalysers and the optimised racing header render the sporty and earthy sound of the V8. On the other hand this is a substantial part of the profound modifications at the serial power engine of the Cayenne Turbo. But the main feature of the engine makeover is the increase of the cubic capacity up to five litres. Here, the GEMBALLA engine experts fitted fortified forged pistons, special connecting rods and racing turbochargers. An air intercooler with a 90 percent larger cooling area supplies enough cold air. All these components are precisely adjusted to each other with the help of new engine electronics maps.
    The result: with a top performance of 750 hp / 552 kW at 6,400 rpm and a maximum torque of 1,050 Nm at 3200 rpm, the GEMBALLA engine meets the wishes of its ambitious customers from motor sports and also renders excellent performance values. The 4WD automobile accelerates from 0 to 100km/h in only 4.3 seconds and with a maximum velocity of over 300 km/h, the GEMBALLA TORNADO 750 GTS is significantly more powerful than its serial counterpart.
    Running gear and wheels for adequate grip and agile handling
    The TORNADO was equipped with an adjustable coilover kit which has been especially adjusted to the enormous performance potential. This allows lowering the car by up to 70 millimetres and therefore permits a variable adjustment of the setup to every individual driver and scope of use.
    The right grip is provided by the tailor-made wheel-tyre combination for the GEMBALLA TORNADO 750 GTS: The multi-part, especially light GT SPORT forged rims are available in 12Jx22 with tyres measuring 335/25 Z 22.
    By manufacturing the wheels in forged technology, they are extremely light. Moreover, the weight of the unsprung masses is reduced which significantly improves the handling as well as acceleration and braking response.
    The high-performance braking system with the punched and slit XXL discs guarantees optimal deceleration values. In order to provide the perfect gas pedal response, the GEMBALLA technicians used 6-piston brake callipers with 420mm discs at the front axle and 4-piston brake callipers with 380mm discs at the rear axle.
    4-seater with state of the art interior
    As usual, GEMBALLA builds the interior in an unsurpassable quality and in an innovative design. The four single sports seats which offer all passengers a unique seating experience when driving winding roads are another highlight. The hand-holds which are embedded in the rear centre console provide further support.
    The new front centre console with the lifted gearbox and the Data Control System renders a real cockpit feeling. The harmonically integrated display presents driving data such as acceleration, cross-acceleration and deceleration values. But also comfort is not neglected in the TORNADO: Stylish and in artisan perfection, GEMBALLA integrates state of the art Rear Seat Entertainment components and combines these with finest materials, such as high-quality leather, carbon fibre or aluminium.
    GEMBALLA - the specialist for high end Porsche refinements and innovative engineering design offers the GEMBALLA TORNADO GTS in a limited edition of 50 cars for a price from 400,000 euros.
  2. FTZ
    That's hot. Not a big fan of the entirely wrapped interior. Aside from that the car looks pretty sick. I like the flat grey paint look almost as much as the flat black they use on the Carrera GT.
  3. Cool_____
    That's a serious grocery getter. 750 hp! 12 inch wide wheels! :eek:
  4. mmtasty
    mmtasty Active Member
    Blah! What the heck is that?!
    The shift boot looks like a suede vagina with a dildo sticking out and the wheel looks like someone won it from one of those games with the crane claw that picks up the stuft animals that you know is bullshit and you still try.
  5. Cool_____
    What is it? Something that'll spank that Fozzy of yours and my car without trying! :rofl:
    The car is okay but I saw the interior and had to post it up for Alex since he's all about alcantara interiors.
  6. Alex
    Beautiful workmanship :)
  7. Cool_____
    Yeah but what else would you expect for OEM from Porsche?
  8. blaster
    This.
  9. JPM Coachworks
    JPM Coachworks Registered Vendor<br/>Its delux son, delux. Supporting Member
    Gemballa no less ;)
  10. pEd
    I would HATE to buy tires for this thing.... 335's at all four corners!! :eek:
  11. wrxin8or
    That steering wheel is horrible. It looks like a giant pillow...I would never put something like that in my car
  12. SubiNoobi
    SubiNoobi Supporting Member
    If it is made in Germany, why is it right hand drive?
  13. Cool_____
    It's a luxury sports/SUV car dude.
  14. Cool_____
    Not all of Europe is left hand drive.
  15. dontcallitarex
    dontcallitarex Active Member
    This is just excessive.
    However fucking incredible it may be. An SUV that'll run with a 911 turbo? Sign me up, shit.
  16. SubiNoobi
    What parts on mainland Europe are right-hand drive?
  17. Cool_____
    There are sections here and there that are left side drive therefore they make cars for both. France has some areas like that. I've seen plenty of TopGear shows where they are racing across Europe in a rhd car.
  18. yerrow
    yerrow Active Member
    That bodywork is heinous
  19. Jake
    Yeah too much body kit and way too crazy on the wrapping of the interior. I'd drive it for a week and then sell it
  20. FTZ
    It is over the top no doubt, but I wouldn't say it is hideous. It looks mean as hell. I kind of like it.
