Yes but you will need to run side feed injectors which means you need the fuel rails with the intake manifold.
Ok. I just received a set of 565 cc Deatschworks injectors I am assuming they will work and the "side feed" is based on the the rail not the injector. Or are the injectors proprietary as well?
