intercooler
Discussion in 'Modifications & DIY how-to' started by josh booth, Jul 25, 2006.
  1. josh booth
    josh booth Active Member
    I just bought a sti top mount what will this do for my 2003 wrx.
  2. suby113
    suby113 Member
    Nothing much really until you get tuned. looks cool though! May help out with better cooling but not sure if you'll notice a difference.
  3. josh booth
    What about after i get tuned?
  4. suby113
    suby113 Member
    You should then! but first I would also get a TBE if you don't already have one, then you could stage two it with a tune, then you'll notice a difference.
  5. nsvwrx
    nsvwrx Active Member
    not sure if therd be a much of a diff even with a tune vs the stock WRX IC
    esp since you dont have a bigger turbo...
  6. clemsonscooby
    clemsonscooby Active Member
    There will be a difference. Large IC has a more efficient air to air cooling capacity. Also, it has a better design, so there is less pressure loss from the compressor of the turbo to the throttle body. Of course there are better bar and plate designs out there that will decrease the loss even further (ebay IC). A tune would definitely help the situation out as well. Since the cooler the air coming in the more you can shove in your engine.
  7. suby113
    suby113 Member
    True!
  8. nsvwrx
    ah, well didnt know the stock turbo would really go for all that =)
    You learn something everyday!
  9. josh booth
    Thanks guys one more thing is this a stright drop in? what is a tbe?
  10. nsvwrx
    well, id get y-pipes (new ones the plastic ones suck ass.) if you plan on an easy install.. its not too hard.. couple of bolts.. and a few clamps notthign too difficult...and a TBE is a Downpipe + cat back exhaust. They do WONDERS for your car with proper tuning
  11. suby113
    suby113 Member
    yes it is a straight drop in may have to finagle the brackets a little but it will go in, just becareful of your boost lines on the turbo and wastegate housing. A tbe is (Turbo back Exhaust).
    we'll looks like nsvwrx beet me to the punch.
  12. miloman
    whether the STi TMIC is a straight drop in is a debatable topic... i have seen it go on smooth as butter on some cars and in others people have had to wrestle with it a little bit... do you have the STi y-pipe? i dont remember perfectly but i dont think the WRX y-pipe will fit
    tbe = turbo back exhaust
  13. josh booth
    I just got 3in cat back exhaust this past weekend.
  14. nsvwrx
    woot what cat back?
    and yes if i were u id buy a silicone y-pipe
  15. clemsonscooby
    Thought the Y-pipe needed to be cut or something.
  16. josh booth
    It's a coustom system.
  17. miloman
    custom y-pipe?
  18. nsvwrx
    he means the catback
  19. 1ll-WRX
    definitely....hopefully you'll have no issuse :sx:
  20. josh booth
    So far every thing is good next puting on a test pipe then it should get good.
  21. techlord
    ^^^Josh, I did the swap to my bugeye...stock STI intercooler, turbo, and pink injectors. W/ tune got a net 67AWHP @ 6000RPM. Just at 300hp to the ground.
  22. josh booth
    Dude thanks thats what i was looking for sounds good to me.
  23. Weapon
    really?!?! 300hp to the wheels with the vf39..that seems very high for that turbo..Can I see your dyno plot :wiggle:
