Is it time for new Rotors or bearings?
Discussion in 'Modifications & DIY how-to' started by RoMe, Apr 20, 2010.
  1. RoMe
    RoMe Active Member
    Im getting a squeal from the left front wheel at slower speeds 10-15mph. Its not the brake squeal because my pads have plenty of life left in them. I felt my rotors and there are groves in them could that cause the noise?
    Or does this sound like me bearings are going?
  2. integroid
    does it squeal all the time or only when the brakes are applied?
  3. techlord
    just get the front end off the ground and see if the wheel has play...by the time a wheel bearing is making that noise the wiggle test will be obvious.
    what pads do you have?
  4. RoMe
    RoMe Active Member
    Mostly on turn in, when I brake is goes away. They are HPS pads Ill do the wheel test tonight.
  5. Trey
    Trey Active Member
    If it gets louder when you turn in one direction then it sounds like the bearing. Mine didn't squeal though...made more of a worring noise. wor...wor..wor...wor..wor.
  6. SubiNoobi
    SubiNoobi Supporting Member
    My HPS pads do squeal, a little bit. That can be fixed with some of the right grease on the back of the pad.
  7. techlord
    my bet is the pads, I have a bad wheel bearing now (not yet squealing)but when I hit the brake the feedback in the steering is scary...I drive WOT or STOP!
  8. RoMe
    RoMe Active Member
    Well I did the wheel bearing test that there was no movement so yeah still cant figure this put. Im gonna try to take off the wheel and take the pads out tomorrow to see whats up
  9. bluedestiny
    bluedestiny Supporting Member
    I have similar issue, installed new HP Plus Pads, turned rotors, and the right front [maybe rear too] likes to squeal after they get heated up a bit and when easing off to a stop- hard stop = no squeal, light touch= loud squeal; heavy touch=no squeal.
    Tried reversing the symetrical separator plate that holds the pads apart, re-cleaned and substitued CRC Disc Quiet instead of hawk supplied grease. Mystery squeal still there.
    Left Side= quiet. Maybe redo the rear with CRC Disc Quiet next
  10. b reel
    Betting on a pad not playing nice, but could be a slight warp in the rotor or lugs not torqued right. Would pull the rim off and clean the mating surface between rotor and rim also.
  11. bluedestiny
    Thanks-BTW, lug torque was set to 85 ft lbs in sted star pattern from what I thought was good reference, however after looking this up http://forums.nasioc.com/forums/showthread.php?s=&threadid=450557 2005-2007 STI wheels are 17 x 8 with a +53mm offset and weigh 19.2 pounds. Lug Pattern: 5 x 114.3, Lug Thread: 12 x 1.25, Lug Torque: 65 ft/lbs, Lug Nut size is 19MM. it looks like most often cited spec is 65 ft lbs.- think that could be part of the issue?
  12. Sparta
    Sounds like normal HP+ behavior to me, they are known to be noisy when lightly braking.
    Jerome's issue seems to squeal without brake touch indicating something is off.
  13. Sparta
    :hsnono:
  14. RoMe
    RoMe Active Member
    That's exactly it but I haven't had time to take the wheel off and clean everything or even drive the car. I need to do both soon
  15. techlord
    DAMN I have been doing 100 ft/lbs.
