Ok I just got my new short shifter from goixiz. http://ixizconcept.com/ixizshift.htm It is a direct replacement using a stock shifter. It is preset to reduce the travel by about 25% and if feels great over stock. It can be adjusted to almost 40% shorter throw. Ming has taken all the play out of the bushings in the shifter which helps with the crisp feel. I bet with the Kart Boy lower bushings the feel would be even better. It is my first short shifter but I can't imagine it could get any better then this. It is a fine product at a price that anyone can afford. So the Ixizshift gets a :bigthumb: Andy
thats awesome..congratz..the shifter bushing will definately help.. If you want a really nice combo do the Kartboy shifter bushing + Group N Tranny Mount..you will thank me later!
Ive installed a few and 15 minutes tops but occasionally the steel plate that has the top left corner interfering needs to be cut (+30 minutes). I recommend cut it anyways for future if you need to make the shortshifter even shorter. Its shipped at about 30% reduction in throw.
