Jack Slipped While Jacking to Change Oil => Dented Oil Pan
Discussion in 'Modifications & DIY how-to' started by nygiant, Apr 19, 2015.
  1. nygiant
    nygiant Member
    Jacking up the front to change oil and rotate tires, the jack slipped off the front central jacking area and ended up on the oil pan.
    Should I have the pan replaced or is this not that bad of a dent? Oil pick damaged maybe?
  2. orndog
    orndog Member
    That doesn't look all that bad to me, but it's hard to be certain in a 2D image. How far in is it dented?
  3. nygiant
    nygiant Member
    I will get back under and snap a better picture and rest a straight edge against it for reference
  4. nygiant
    nygiant Member
    Well I couldnt get a good picture because of the gloss from the pan. It seems to be dented in about 1/4", maybe a tad over in a certain spot closest to the bolt hole.
    I ended up draining the oil, then stuck my pinky finger in the hole to feel around :naughty: . The dent did not contact the oil pick-up and there seems to be a hair less than 1/2 inch of space from the bottom of the pan and the pick-up now. So I guess I should be ok. I will monitor the oil pressure with my AP.
    Edit:
    just realized AP doesnt monitor oil pressure.. wtf
  5. I would get the vehicle safely lifted and remove the drain plug to see if their is any type of clearance problem with the oil pickup.. If not the I would leave. I have seen cars with fairly good sized dents on the road..
  6. Drowland87
    Drowland87 Staff Member Supporting Member
    I just upgraded to a killer b oil pan so I have a oem sti pan with 65,000 miles for sale.
  7. integroid
    and if you are going to go through the trouble of replacing pans, you might as well replace the pickup with a killerB
  8. FACE
    I would get the killer b sump tube and upgrade it while I had the pan off...killer b products Rock!
