JDM wrx rear vented brakes
Discussion in 'Modifications & DIY how-to' started by SubiNoobi, Jun 20, 2007.
  1. SubiNoobi
    SubiNoobi Supporting Member
    I am currently refurbishing a set of single piston vented rear brakes
    I have already painted the calipers and brackets and am not taking them apart so that I can put new seals on them, as some of them, including the piston seal are torn.
    I ordered a seal kit from SOG, but it must be for the USDM brakes, because the new kit does not include this:
    [​IMG][/IMG]
    [​IMG][/URL][/IMG]
    This seal came off the slider pin that is held in by long bolt. It is much longer than the seals I got. The bits of orange are from the caliper paint. I did not bother taping off these because I am replacing them anyway.
    So where can I find this part? And what part do I ask for?
  2. SubiNoobi
    I found out that these are from an older 91-94 turbo legacy. I called up to SOG to order the seal kit, and they need to know if they are from a sedan or a wagon. Is there any way that I can determine this from the brake parts themselves?
