Just got TBE for Sti need help installing.
Discussion in 'Modifications & DIY how-to' started by s2kbrian, Oct 4, 2005.
  1. s2kbrian
    s2kbrian Member
    Bought a perrin tbe exhaust for my sti. just wondering how hard the install is if i do it myself? any special tools or anything? also is there anyone near atlanta that can do this install for a resonable price. i would like to get it done either on friday or sat this week.
  2. jonnyboy0150
    jonnyboy0150 Member
    You can do it with a jack, jack stands, and a basic tool set. The install is fairly simple, the up-pipe is the tricky one. Also you might consider heatwrap on the downpipe to greatly lower underhood temps.
  3. lostinthewoods
    Woo hooo another Perrin exhaust. Good choice man :)
  4. moose
    Invest in some PB Blaster and you should be fine. However, it is not unheard of to have crossthreaded studs/bolts from the factory which can turn into a real pain... disregarding that, install is pretty damn easy.
  5. Weapon
    yea it is very easy..PB Blaster is your best friend though
  6. bigb996
    just lube it up man.....i put my TBE on in about 2 hrs flat. It always helps to have a helper htough and especially if its someone you know.
  7. Alex
    If I can, I'd be more than willing to give you a hand. Not sure how my schedule is going to look on either day. Worst case, I'll give you my number and I'll walk you through whatever you need to know.
  8. UBAR
    UBAR Member
    Just need some WD40 set 14m wrench and socket along with a 12 for nut on res. should be easy not too hard. Use the 40 or brake cleaner to get them off an on hope it works out OK.
  9. s2kbrian
    s2kbrian Member
    Intercooler have to come off?
  10. RADON
    RADON Member
    It's a whole lot easier to get access to heat shield bolts if you do.
  11. Alex
    If it helps, I'll write a DIY up.
  12. rolling_trip
    rolling_trip Active Member
    i just did the heat wrap this weekend, make sure you get the 2" if you do it, and expect the downpipe to smell really bad for a day:barf:
    BTW you may want to pick up a new down pipe gasket before you install it, to keep it from leaking, trust me.
  13. lostinthewoods
    Where did you end up finding the heat wrap and how much of it did u wrap?
    Just curious bro :cool:
  14. Brian
    Brian Active Member
