Just Installed Cai Do I Need To Reset The Ecu
Discussion in 'Modifications & DIY how-to' started by Intrigue2727, May 26, 2006.
  1. Intrigue2727
    Intrigue2727 Member
    Do I Need To Reset The Ecu Or Anything Like That?
  2. miloman
    i'd recommend resetting the ECU after any mechanical mod
  3. bluetwo
    bluetwo Active Member
    I'd say yes. Do a hard reset, or one that clears everything. You'll have to reset the FM presets if you have a factory stereo but it's worth it to ensure the ECU does the best it can.
    ...IMO
  4. Weapon
    yes..reset NOW!!!
  5. FTZ
    It never hurts to reset your ECU after any mod.
  6. Intrigue2727
    Intrigue2727 Member
    how do i do a hard reset?
  7. miloman
    i doubt u need a hard reset... just disconnect the battery, step on the brake pedal for 5 seconds and reconnect the battery
  8. suby113
    suby113 Member
    I also agree! usually works fine.
  9. ScoobyMike
    ScoobyMike OG Mod
    we know what happens when you don't reset......vrooommm bang bang bang...vrooommm bang bang.......hahahahahha
  10. miloman
    hahahahaa.... that was freakin hilarious
  11. WrxCrazy
    WrxCrazy Active Member
    i ran my short ram just fine without reset.. why is reset important??
  12. miloman
    since the ECU is adaptive, it learns to run as well as it can with the current setup... if u change something then it could run wierd... if u reset, it starts somewhat conservative and tries to converge to the best state for that setup...
    obviously the adaptability is limited, hence after a set of mods, u need a tune
  13. Intrigue2727
    Intrigue2727 Member
