just installed STI side cowls
Discussion in 'Modifications & DIY how-to' started by feelthebreak, May 15, 2009.
  1. feelthebreak
    feelthebreak Member
    i have had these sitting around in my basement forever. put them on today. here are the pics... you can tell how much better they are the crappy stock stamped steel...
  2. Bug-Rex
    Bug-Rex Active Member
    Nice! Make a DIY. Never seen this one done.
  3. XanRules
    XanRules Active Member
    noticeable difference in handling?
  4. nicad
    I've had this sitting around for over a year LOL
  5. feelthebreak
    feelthebreak Member
    you can't tell a difference behind the wheel, but i can flex the oem piece in my hands. so you be the judge...
  6. AtlxPat
    AtlxPat Active Member
    i heard aftermarket fender cowls make a HUGE difference, such as paranoid fabrications.
  7. wagunz_pwn
    1. Remove fender
    2. Remove stock brace
    3. Replace w/ new brace.
    4. Replace fender.
    5. Repeat on other side.
  8. Alex
    I have never driven a setup with these, but I fail to understanding how this makes even a marginal improvement.
  9. feelthebreak
    feelthebreak Member
    if you do install this make sure you have some of those cheap plastic black clips, you have to pull the front bumper and remove the headlights too. ive got about 6 of those clips to replace that broke. plus i found rust on the welds you can see in the picture, car has always been garaged.
  10. goixiz
    goixiz Active Member
    very noticeable difference
  11. Matt
  12. Alex
    Aye, but their explanation isnt exactly all that explanatory.
  13. Bug-Rex
    Wow! Now with these step by step directions I think I can do this! Thanks Matt! :fawk:
  14. wagunz_pwn
  15. blindfold
    blindfold Active Member
    are these the 07 cowl peices ?
  16. nicad
    I have the TiC ones afaik. when I take my fender in to get painted here pretty soon I'll go ahead and throw them on
  17. Slowsoul
    Slowsoul Member
    They further reinforce the unibody by tying the engine bay to the cabin...anything that helps to keep it from twisting is good.
  18. Koolaid
    Koolaid Member
    how much more horsepower at the wheels?
  19. Cool_____
    Alex I thought the same thing. Then had a buddy make some. Tried to install at my house and could not get clearance for my hand. So I drove home with one off the car and the other stock one on. I took the turn fairly hard onto my road like I always do and next thing I know I'm understeering onto the shoulder. It makes a difference.
  20. FACE
    Humm sounds like a great bang for the buck...
  21. techlord
    I can see it's use, I took the stock one's off the banana and put on the coupe.
    Ped said his buddy has a bolt in cage and it made a huge improvement on body twist.
  22. dundunskeert
    dundunskeert Member
  23. dundunskeert
    dundunskeert Member
    Installed them today.
    They definitely make a difference.
  24. mmtasty
    mmtasty Active Member
    I have a set I'm waiting on I got through a group buy. I'm excited! I hear they help a lot. But then, that's what they said about my rear strut tower bar... and all that does is get in the way.
