Installed my struts last night and after securing my wheel lugs on my front left, luckily before the wheel fell off...lol, I drove home with them on the 1 setting. Seems to be quite stiffer than stock yet not too bad of a ride. I will try the 4 setting today and review the contrast later. current setup is kyp struts and whiteline control springs. no sway upgrades yet
Glad to hear you got them installed and like them. Make sure the road is pretty smooth when you try out the stiff setting. When you get the sways it should turn flat. I still had the car rolling over until then.
level 2 just set the fronts to level 2 for kicks while ago at lunch. Damn if you can't tell a difference! I can only imagine level 4....I'll be bouncing down the road.
