Launch control question on a AP2
Discussion in 'Modifications & DIY how-to' started by RoMe, Aug 7, 2008.
  1. RoMe
    RoMe Active Member
    So I got a AP2 a couple of days ago, and I'm tempted to load the LC map but reading on other forums no one really recommends it. Whats everyone thoughts on LC as far as the benefits or potential issues?
    ATTN *Newb question*
    And whats the purpose/use of Flat foot shifting?
  2. WJM
    DONT DO ANY OF IT!!!!!!!!!!!!!!!!
    EXTREMELY harmful to the engine. It WILL break a piston.
  3. Sparta
    Jerome's turning into a Skreet Racer
  4. RoMe
    RoMe Active Member
    yeah son!
    no not really
  5. WJM
    ^good. lol
  6. oneiguy
    oneiguy Active Member
    Answer yo fone
  7. RoMe
    RoMe Active Member
    what is a phone? :rofl::rofl:
    in other news the AP 2 is the sick, getting tuned on Sat
  8. Sparta
    Call me on 3way!
  9. RoMe
    RoMe Active Member
    that sounds so sexual :keke:
  10. oneiguy
    You are wrong:)
  11. RoMe
    RoMe Active Member
    yundizzzz send me a pic of how you mounted your AP2
  12. oneiguy
    This is what he used. (sorry dude to easy):rofl:
  13. 2thAche
    2thAche Member
    LC is not necessarily bad. If you put it to the floor and sidestep the clutch, of course it's abusive. But if you use it to hold a consistent rpm while your foot can be at a higher throttle point, and launch reasonably with the clutch like you should, it's actually very useable to get consistent starts.
    FFS I really don't see a point for unless you're into drag and want to bang gears.
  14. FACE
    per pEd learn to do it with your feet
  15. schneid
    schneid Member
    so ffs and lc are way bad...i see no immediate need for ap2 now. oh wait, its got a color screen and a usb interface....uhh, still no.
  16. Meredith
    Meredith Banned
    It's horribly bad for the engine, it put way too much load on it. It's extermely useful for ProSOLO and many autoxs in which you have a straight start. However my nationals co-drive from last year blew a piston ringland at the DC Pro this summer after many autoxs of using the AP2 LC. My car was also a victim of the this too.
  17. Sparta
    I love my AP2, with its live readings I can monitor whats going on and change maps on the fly. You know, cruise around on a conservative map, and then when some Asshat in a 350z gets up next to me on the Highway I can switch over to my overkill map and blow his doors off doing like 150 mph in the death wagon or should I say wagon of death. V2>V1 if your a hardcore skreet racer that wants to be able to save gas without having to pull over on the side of the road to change maps.
  18. WJM
    All the LC is: Fuel cut rev limit set to an RPM defined by AP/ProTuner/StreetTuner tuning.
    Fuel cut rev limit hold is BAD BAD BAD. Creates a LEAN condition at FULL BOOST that will crack the pistons.
    Mere and BrianGT know this personally.
    So does Crash477 on NASIOC.
  19. 2thAche
    2thAche Member
    Full boost, you're talking about after clutch is out? I'm not power braking.
  20. WJM
    The COBB LC program allows full boost to be built under LC conditions.
    Thats BAD.
    Power braking is SOOOOOOOOOOOOOOOOOOOOO much safer and easier on the engine than LC.
  21. Cool_____
    I know a guy that was using LC and his engine got so hot that the car caught on fire. Total loss. Of course the idiot was staying in it because it made cool backfires.
  22. techlord
    ^^as long as the car does not catch on fire, I am willing to sacrifice the engine. SB's are cheap well relatively speaking compared to a tranny. As far as I am concerned 6mt=use LC. Now COBB just come out with a drive by cable version of LC!!!
  23. 2thAche
    2thAche Member
    Oh I've never held LC long enough to build boost. I've launched with it maybe twice, holding for for 2 sec tops. If it's that bad, I'll just disable, I'm not into dragging anyway.
  24. WJM
    Disable it! Its bad either way.
