launch control
Discussion in 'Modifications & DIY how-to' started by davo 1979, Jul 13, 2010.
  1. davo 1979
    davo 1979 Member
    is launch control out for the cobb access port 02wrx
    just updated mine and it was on it
  2. techlord
    Wirelessly posted
    Sweeeet, got to get my kill map on it
  3. davo 1979
    davo 1979 Member
    ya i agree i wasnt expecting it . i hooked it up to the car and their it was waiting for me to set the rpms
  4. techlord
    well Mike (Killshot) told me it was coming soon, I just forgot...Cobb told me they would have it out over a year ago, bout f'ing time!
  5. Cool_____
    What type is it? Fuel or ignition?
  6. davo 1979
    davo 1979 Member
    launch countrol
    dont know i just saw they had a update on their page for some problems they were haveing so i downloaded it. when i hooked it up in the car it was their .
  7. Alex
    Wirelessly posted
    I assume you have v2?
  8. techlord
    Bump for an answer to this question...Calling all tuners
  9. Meredith
    Meredith Banned
    Use at your own risk... I'm convinced part of my ringland failure was due to all the load on the engine using the V2 AP launch control for the STi... the STi I codrive at nationals had the same thing happen to it's engine about 9 mouths after mine with frequent use of launch control.
  10. Cool_____
    ^^^I agree. Cobb's method of launch control flat out SUCKS.
    Want launch control? Get an antilag system or go OS.
  11. wrxin8or
    Yeah because it had nothing to do with the fact that 40k of the 50k miles on your old STi were racing;)
    And everyone beat the hell outta your car
  12. Matt@Topspeed
    Matt@Topspeed Member
    The launch control from Cobb flat out sucks, ringland failures on Subarus are almost always caused by ring gaps that are way to tight. You wouldn't believe how tight they are from the factory.
  13. techlord
    guess the answer to my question doesn't matter I need to blow up this 2.0l so I can put in my 2.5
    must get soon
    YesIhaveaFuckIng6MtBiOtCHes - wait...I have 2...
  14. UpSideDownDesi
    UpSideDownDesi Active Member
    finally i can put 6spd to good use, not that i launch often (launched the car prbly 3 times since i have owned it lol). Anyone find out if it ingnition or fuel cut?
  15. Mike@TTR
    Mike@TTR Active Member
    Hmm, still not updated on their site. Did you test it to see if it worked? On the features page it still lists it as not being a feature.
  16. techlord
    looks like it to me
  17. UpSideDownDesi
    did see it on site either or read about it either anywhere else.
    Edit: http://www.cobbtuning.com/products/?id=3264
    FFS too :D. I guess i'll test it out this weekend to see if there for shizzle dizzle.
  18. Mike@TTR
    Official word from Cobb is that it is not released yet and it is still in Beta. FFS is not going to be coming out for the 16 bit ecu's to the best of my knowledge.
  19. Meredith
    Meredith Banned
    My car was completely stock for 45k out of 50k miles.... (well except for the ohlins stocks)......
  20. tolnep
    tolnep Member
    what does 'adjust ignition timing in real time' mean?
    you can do that with ATR. you tweak the ignition map.
    does that mean you can do it somehow with the ap thing itself?. not sure how that would work since you go in an tweak the cells....
  21. UpSideDownDesi
  22. Doug@DBW Motorsports
    lol.... The new ap updates allow the end user to adjust launch control via the AP. However it will not work unless you flash a launch control enabled map onto the ecu, which is not out yet for the 2.0L wrx.
