Leaky recir/bov
Discussion in 'Modifications & DIY how-to' started by crashtke, Sep 1, 2006.
  1. crashtke
    He just curious what a leaky bov sounded like. I think mine may be leaking. I noticed that the pitch of the sound varies and with the new silicon hose for the bov I can hear it better.
    Is the Bov/recirc valve supposed to leak boost at part throttle or is it the wastegate that is supposed to regulate that? I am a bit confused. I notice a whistling sound that changes every time I shift, but it is the same noise, just different pitch. Anyone know what I mean? I know miloman said his was leaking previously. Any thoughts?
  2. 1ll-WRX
    a leaking BOV would be not tight to the TMIC...missing a gasket would do this...if you have an intake you can hear a re-spool like noise....
  3. crashtke
    ya kinda sounds like that...Guess I need a new recirc valve. It has a gasket and it is not leaking there, checked it with water. I think it is recirculating when it does not need to be/leaking boost back into the system.
  4. miloman
    the stock BPV can handle close to 22psi... so unless yours is defective, i doubt yours is mechanically leaking...
    mine was leaking on my WRX but i was running close to 23psi... i couldnt hear it leak though...
    on my STi, we had a BOV leak because it didnt seal well with the TMIC... so i double gasketted it and its been fine ever since... that one i could hear... sounded like i had 10 kittens stuck in the radiator fan
  5. crashtke
    no, no does not sound like that, I dunno, maybe i should let someone hae a listen who knows what the hell they are listening for. But is the gate what regulates boost or is the BOV the regulator on part throttle operation?
  6. goixiz
    goixiz Active Member
    try to isolate it
    if you can hear it at idle then
    get a wooden dowel 1/2-3/4 diameter 2feet long and use it as a stethescope
  7. miloman
    the BPV is not used to regulate boost... all it does is let excess pressure out when it isnt needed... if u didnt have a BOV or BPV, the excess boost would try to escape backwards through the turbo, making it spin the other way
  8. crashtke
    Ok, then I probably should not hear it when I am spooling correct? I can not hear it at all at idle. I only hear it at part throttle (kinda spirited, but not all out) acceleration and when I shift. Seems like it may be recirculating boost even when I am not needing it to...wonder if the spring is dead on it or it is faulty. That seems like it would be a pretty good reason for the rich conditions I am experiencing and the lack of full boost, slow spool. I can hear it recirculating all the time and I hear it release all pressure when I shift. Sometimes it does not even do that and the RPM's will stay up after I let off the throttle for a few seconds.
  9. crashtke
    ok went out and did not log, but had a friend watch the boost gauge and call it out to me...the cobb meter was used to read it. At a set point with my foot on the gas, flat road, the boost climbed to about 5 psi then slowly bled off. I tried this several times at part throtle and it seemed to bleed off every time. With RPM's not climbing I would think that the boost would stay the same right? Maybe slight fluctuation, but not bleed off? Again, first turbo car so not sure about these things...
    Anyone?
  10. crashtke
    anyone?
  11. moose
    Unlike that it's the BPV. If no pressure is bled off the actuator line then you'll see a max of 7psi or so; maybe this is what's going on.
  12. crashtke
    sent ya a pm moose. I guess my real question is should it hold solid boost at a set RPM or is it supposed to bleed off?
  13. crashtke
    well so far have some people on nasioc saying it should hold boost at a stable rpm...mine is not. Either gasket, bov (factory), or boost leak.
  14. nsvwrx
    nsvwrx Active Member
    it SHOULD hold boost. at a stable rpm and NOT bleed off.
    sorry i misunderstood your question.
    look like you might want to check out ur y-pipe and get some new y-pipe and bov gaskets
  15. crashtke
    Brand new y pipe gaskets. They came with the new IC. I will try a new BOV gasket though. I guess I can check the torque on the bolts of both y pipe and bov again also, but don't think that is the issue...it really sounds like it is the bov releasing air...I can hear the tone change when I shift. Guess i will see.
  16. miloman
    i dont remember the stock boost curve but my cars have been tuned by SS and he always implements a boost taper
  17. crashtke
    That is where it just goes down after 4k rpms right? Mine is doing that now with cobb stage 2 map. Oh well, will try the gaskets then see how it feels. I really need to get a boost gauge so I don't have to keep plugging in the AP.
  18. miloman
    i honestly dont think u have any problem here... a whooshing sound when u accelerate is expected and it isnt coming from your BOV... is there anyone close to u with a modded WRX/STi?... have them ride with you and they can let you know
  19. crashtke
    Honestly I am not sure. I have seen several around the area, but have not met any from here. I may just try the gasket (what like $5) and if that makes no change, wait till I get the new turbo (if Tray ever writes back) and let the tuner play with it.
  20. miloman
    try to make it down to a meet and have someone ride with you
  21. crashtke
    Ya bad part is most of em are during work time. I usually have weekends off, and I was at a certain meet (scavenger hunt) and someone was missing...
  22. miloman
    any particular someone you referring to? ;)
  23. crashtke
    Hehe was looking forward to meeting ya despite what Ken says about you!
  24. miloman
    hahaa... well, im back in ATL now so i should be out at meets...
  25. crashtke
    I'll be at Nopi and also helping out this weekend on Jason's (WRXFan420) vehicle.
  26. miloman
    my attendance at either one is not guaranteed... in fact my attending events is going to be a little flaky till the end of september... got way too much on my plate
    however, jason should be able to tell u if the sound your car is making is normal
  27. crashtke
    Ahhhh so all the stuff Ken said about you going out and posing as a transvestite prostitute in Little Five Points IS TRUE!!! J/k hope you can make it to something sometime soon, but I understand obligations.
  28. miloman
    ah yes... he knows me so well :D
  29. crashtke
    Got the gaskets today btw...install hopefully toorrow. Just a new one or a double? Not seeing how a double will help, but several have recomended it.
  30. miloman
    try double... it will help if the fitment isnt perfectly flush
  31. crashtke
    Gotcha was going to do today, but called in to work early :/
  32. crashtke
    Ok installed the new gasket, noise seemed to quiet a bit. Also when at WRXfan420's place I got to ride with him in his vehicle. We plugged in the AP and I was able to watch and see what his boost was doing at any gien RPM. I guess it is natural when holding at a set rpm for the boost to fade back down. At least that is what is happening on both of our cars. It goes up to around 5-7 psi then slowly bleeds back down. I guess that if it is not climbing the computer automatically decides to let it fade back down. So, conclussion, while his turbo does not seem to make the same noises that mine does, he also has different DP and exhaust. Mine may have had a tiny leak in the BPV gasket. Getting a new gasket is worth the $6 when installing a new IC or BOV. Also his BOv is a Forge 100% atmospheric and it did not stutter or bog in the least between shifts as soome claim that the 100% atmospheric valves do. But, he also has a custom tune from Scott Seigel on his car. Could make a difference.
  33. moose
    Wait, you're seeing 5-7 at part throttle that bleeds off? That's entirely normal; I thought you were seeing that as MAX boost. There's just not enough load to continue producing boost, and that's why it creeps down.
  34. crashtke
    Ya 5-7 at part throttle held at a certain rpm. Like half throttle at 3500 RPM cruising on a road. But yeah found out it is normal ;)
  35. crashtke
    Ok after installing the new intake I can hear the air recirculating at partial boost and actually hear the PBV open and close....it is not actually closing until up to 7 psi some times. And even when it is closed you can stil hear a bit of a leak...got a new bpv/bov on the way. I found a GFB 50/50 for a bill. I guess we will see if this is my issue or if I am just paranoid.
