LGT Daytime Running lights?
Discussion in 'Modifications & DIY how-to' started by jonnyboy0150, Jul 4, 2006.
  1. jonnyboy0150
    jonnyboy0150 Member
    My mom has 12k miles on her 05 Legacy GT and has already burned out both headlamp bulbs. She was wondering if I could diable the Daytime running lights like I did in my 02. Anybody know the best way to do this?
  2. jayj713
    jayj713 Member
  3. 1. Lower the panel above the pedals
    1. There are three plastic attachments for the lower panel. For the two in each side, turn counterclockwise 90 degrees, and the screw head part will pop out, now you can grab it by hand and pull it out completey.
    2. The middle attachment you must use firm pressure on to pull it out.
    2. You will see the DRL module on the firewall with a white and black connector. If you can read the green sticker on the top it will say "DRL" on it.
    3. Pull the white connector out only, secure it so it does not rattle, perhaps with a zip-tie as shown
    4. Put the panel back.
    1. Just push the middle attachment back in
    2. With the "screw head" part of the black attachments extended, push it into the two holes on the sides. Then push the screw head in to lock it into place.
    What is her LGT? I might have seen her 0_o
  4. jonnyboy0150
    jonnyboy0150 Member
    Awesome man! Thanks for the very informative reply! My mom has a pearl white one with a Nascar Technical Institute license plate frame on the rear. I put whiteline front and rear sways on it last Christmas! She is usually driving in the suwanee/sugar hill area.
  5. Hmm i don't think it was her, i've seen a 2.5 LGT then the lady stared at me at the turn lane.
