Loading Map
Discussion in 'Modifications & DIY how-to' started by nik_05STi, Aug 10, 2010.
  1. nik_05STi
    nik_05STi Member
    I need to reload a map to my ride from a Cobb AP1. My question is do I need the car on or cranked while I wait for the map to load?
  2. thrasher722
    thrasher722 Member
    I would start looking here:
    http://www.cobbforums.com/forums/forumdisplay.php?23-AccessPORT
    When I purchased my car it already had the stage 1 map loaded and I need to know how to use it because I should be stage 2 soon. I also have a version 1 but I am missing the null modem cable. I don't have a serial port on any of my computers so I think I will have to get a USB adapter to use it.
  3. Mike@TTR
    Mike@TTR Active Member
    Where are you located Nik? I would be happy to show you the ropes and give you a hand.
  4. nik_05STi
    nik_05STi Member
    Marietta, I know it doesnt take a long time but not sure if the car needs to be cranked while doing it or not?
  5. Mike@TTR
    It needs to be in the on position with the connectors plugged in. Give me a call if you have any questions.
  6. nik_05STi
    nik_05STi Member
    Thanks Mike, if I have any problems i'll contact you.
