cant wait to put this in along with my ceramic coated turbo heat shield... can't wait to see the improvements :dirty:
NICE....is it way bigger than the sti intercooler?....does it line up in the same bolts as STI atleast?...
its a lot thicker for sure... ive heard it flows much better too... the STi tmic is a nice upgrade for a stock turbo but i think i need more flow with the aftermarket turbo
Looks good. Are you going to get retuned afterwards? That looks a lot like my APS top mount except maybe a little wider and shorter.
i tried calling u but ur too busy to call me back most probably will be selling the STi TMIC... gonna first install the new IC and see if everything seems ok(no leaks, etc.)... i have 2 interested buyers already so they got dibs on it... if they fall through, i'll let u know will need to get it tweaked a little bit... the pressure drop across the hyperflow is lower than the STi TMIC... so i need to make sure im not running too high boost
actually my phone was dead for the first part of the week. I have no clue why, but I turned it off and back on and now its working. everyone who called was going straight to voicemail....*shrugs* seems to work now though.
