Loose steering after wheel/tire combo install
Discussion in 'Modifications & DIY how-to' started by act6464, Jan 26, 2008.
  1. act6464
    act6464 Member
    So I plus sized my wheel and tire set recently and now feel like the car has looser steering. My 2.5i came with 16x6.5 wheels w/ 205/55-16 tires. I put a set of 17x7 wheels w/ 225/45-17 tires. It seems that the steering was much stiffer before the install. Now I feel there's excessive play in the wheel. Any thoughts/suggestions?
  2. siegelracing
    Make sure your lug nuts are tight and that you have enough air in the tires.
    Siegel
  3. Doug@DBW Motorsports
    what kind of tires are you running?
  4. EJRex
    EJRex Member
    You might have changed your angles (camber and/or toe) going with a larger wheel and tire combo.. might just need an alignment.
  5. act6464
    act6464 Member
    Now running brand new BF Goodrich g-force Sport size 225/45ZR-17 on 17x7 ADR-S07R wheels. The set was mounted and balanced at Discount Tire Co in Woodstock. As of today, the tires only have 326 miles on them.
    You're probably right! I'll schedule an appointment for an alignment. Can you recommend a shop?
    Thanks. I'll check them out tomorrow morning. Can't assume that they were torqued and aired up properly at the tire shop!
  6. SonicBoom
    SonicBoom Active Member
    ^^ Gran Turismo East, just inside the perimeter on the north east side... I've been there 3 times and they've allways done me right. Their also highly recommended on this site.
  7. jesus888
    jesus888 Member
    Just popped my Gran Turismo East alignment cherry last week... and I got to tell you... it feels gooooooood. They will guide you through the whole thing. Highly recommended (pardon the harsh metaphor above)
  8. SubiNoobi
    SubiNoobi Supporting Member
    +1 for GTE, they are very good.
    Also, you need to consider the sidewall of your tires. I have two sets of tires: one set of Goodyear all-seasons 205/55/16, and another hankook rs2 225/45/16.
    I notice a significant difference in steering response between the two: The Goodyear allseason have a much stiffer sidewall than the Hankooks. Even though the Hankooks have a narrower sidewall and are more performance oriented, they give me less steering response and more "squish" than my Goodyears.
    Nonetheless, an alignment will help a LOT!
