Loose steering
Discussion in 'Modifications & DIY how-to' started by BlueRex, Mar 19, 2006.
  1. BlueRex
    BlueRex Member
    I have a 03, 36,000 miles. On the highway the tracking is bad, hard to keep it in the lane. Also notice like a slight wobble, can even feel it in the gas pedal. I am also geting alot of road noise, kinda sounds like a sewing machine. I have nitto 225/50's on the stock wheels.I thought it was just the tires but i'm thinking maybe it might be my wheel bearings. The noise did get louder after rotating the tires a couple weekes ago. The tires are wearing evenly, nothing abnormal there. What do you think it could be ?
  2. Alex
    When was the last time you had the car aligned?
  3. BlueRex
    BlueRex Member
    Haven't done it since i got it. It had 17,000 miles when i bought it.
  4. Alex
    Have you added springs since then? Also, maybe I am just missign it, what do you mean a wobble in the gas pedal?
  5. BlueRex
    BlueRex Member
    No, suspension is stock.I mean i can feel vibration in the pedal, feel it in the steering wheel and the brake pedal.Feels like a slight wobble at low speeds and vibration at highway speeds.
  6. BlueRex
    BlueRex Member
    Well i think the wobble may just have been the brakes, seems gone since i changed the pads. I jacked it up, no play in the wheels,nothing feels loose in the steering anywhere. Maybe i just need an alignment. Think i am going to change the steering rack bushings as well.
  7. suby113
    suby113 Member
    Sounds about right! go ahead and do that and I think you'll be ok! :wiggle:
  8. Alex
    Good idea on the bushings, its possible your stock ones are gummed out anyway (mine were by 20k miles). It couldnt hurt anyway, and you will definately feel the improvement everyone "raves" about.
  9. FrankenSTI
    FrankenSTI Member
    I am having the same problem with my bushings Scot from SOG said that mine were about shot, so I am going to go ahead and replace them. But my car has a bad vibration so I changed my front pads and rotors, still same problem with vibration. Could this be a result of bad bushings?
  10. FTZ
    I have a Whiteline Steering Rack Bushing I can sell you if you want it. New, Never been used. Still in orginal unopened package. $30
  11. WrxCrazy
    WrxCrazy Active Member
    at low speeds i thought it should be viberating but i could be wrong, since when idle my wcar vibes like shyt maybe because of the turbo idleing everything in car shakes like mr.shakey pants but at high speeds no shakes but all power
  12. BlueRex
    BlueRex Member
    If they fit a 03 i'll take em.
  13. 1ll-WRX
    that just made my day:rofl: :rofl: :rofl: :rofl:
  14. calmnothing
    ^ Agreed
  15. WrxCrazy
    lol... i try :p
  16. suby113
    suby113 Member
    Mr shakey pants! HAHAHA:rofl: :rofl:
  17. WRXEM02
    WRXEM02 Member
    I just changed my bushings w/ whiteline and i couldnt be happier. Got them for 18 bucks and the install took 20 minutes
  18. WrxCrazy
    not a bad deal at all..
    overall ur car wont shake ur pants anymore.. or likewise.. :coolugh:
