Low beams no workie
Discussion in 'Modifications & DIY how-to' started by Shewb, Apr 8, 2010.
  1. Shewb
    Shewb Member
    This morning on the way in I noticed my neither of my low beams are working.
    Parking lights, blinkers, fog lamps, and high beams all work just fine. I pulled the driver side bulb and looked at, nothing visible to show that it's blown.
    Any ideas?
    it's possible to still be blown. Yes, they can blow at the same time. Did you check your fuses also?
  3. nsvwrx
    nsvwrx Active Member
    mine blew at the same time :/
  4. oneiguy
    oneiguy Active Member
    Time to get a retrofit.
  5. Matt
    I know the perfect people for that.
    www.lightwerkz.net :rofl:
  6. Alex
    Have you checked the fuses yet? 15a for parking/aux lighting likes to go bad sometimes.
  7. Shewb
    Shewb Member
    Man, I wish I could afford a retrofit!
    I'm going out at lunch to check the fuses. Wasn't sure if it would be a fuse since the high beams work.
    If fuses are OK I change a bulb.
  8. Alex
    Highbeams / lowbeams are a relay iirc, but there is a fuse inside the cabin that controls parking lights, rear tails, etc.
  9. Shewb
    Shewb Member
    Both bulbs went bad......go figure.
    Thanks for the help.
  10. Alex
    Dun dun dun!
  11. Shewb
    Shewb Member
    ^^^Yeah, I know. Weird, right?
    We'll see if the new ones die an early death too.
