lower boost?
Discussion in 'Modifications & DIY how-to' started by knhtrdr, Oct 29, 2006.
  1. knhtrdr
    knhtrdr Active Member
    On the way back from my friends house I noticed my boost gauge only went to 10 full boost is normally higher like 12 or something. given its cooler outside is that normal? And I am hearing so kind of "airing" sound that is not the turbo spooling. and there is some sort of substance (too hot to feel) under the dp/turbo area looks like oil but run off from something else.
    any ideas?
  2. yerrow
    yerrow Active Member
    you actually should be able to run slightly higher boost levels with the cooler temps. do you have leak?
  3. knhtrdr
    I don't know I didnt hear it when I was under the hood.
  4. crashtke
    What mods do you have?
  5. knhtrdr
    gutted up, dp,exhaust.
  6. Matto357
    Weird, I've been peaking at 14.2 PSI on my Cobb AP on stage one with all this cold air.
  7. bluetwo
    bluetwo Active Member
    Do you have an oil catch can?
  8. knhtrdr
    Thats whats freakin me out it dropped and did not go past 10 and I opened it up a bit too. runnin just fine yesterday and today till this evening.
  9. knhtrdr
    nope.
  10. goixiz
    goixiz Active Member
    you may be leaking only when boost psi is higher then the leak threshold. Most likely you have a leak
    possible 2 places turb - Y pipe - elbow or IC to TB
  11. knhtrdr
    How would I check that? whats the tb?
  12. bluetwo
    Well I don't know what he meant by TB but I would just let her cool down and see if there's any sign of less oil, which admitedly might be hard to determine. But at least if you can confirm that there's less oil in there then that could be a place to start or be concerned about.
    Lol. I guess I could have just wait to see if you're low on oil!
    But I think there's something else going on there. I've heard of oil building up in the IC and if enough of it builds up it can have a negative affect but I don't think I ever saw what it was exactly. Obviously I wanna understand it too.
  13. yerrow
    throttlebody=tb
  14. bluetwo
    Right! So maybe it's just a boost leak but I just didn't want to rule out other stuff.
  15. goixiz
    check the simple things first
    would be nice if OP is certain it never exceeds a certain PSI eveytime or is it fluctuating
  16. knhtrdr
    I will check things out in the morning when I can see more without a flash light. Maybe run up to Sog if I cant figure it out.:eek:hnoes:
  17. knhtrdr
    I was a little low on oil so topped off all my other fluids while I was there. but I may have a Very small leak some where. On the way to sog the boost started working correctly. Thanks Neal for helpin me out!
  18. goixiz
    so what was it ???
  19. knhtrdr
    A very small leak somewhere but couldnt find it I really need to get some em and a tune soon.
