Master swap list for 04-07 Sti 6 speed into WRX
Discussion in 'Modifications & DIY how-to' started by crashtke, Feb 13, 2007.
  1. crashtke
    http://forums.nasioc.com/forums/showthread.php?t=1201152
    Started this over on Nasioc, but wanted to post it here as well. I will update here as I get more information. If you guys have anything to add please feel free! The thread here should be a bit more streamlined without all the bs that I am sure will eventually happen on NASIOC.
    04 USDM Sti 6 speed:
    -transmission
    -driveshaft from an automatic or from Sti with some modification?
    -3.90 R&P gear to replace the 3.54 in the WRX
    OR
    -R180 rear differential and Sti hubs, rotors, brakes and axles
    -6 speed shifter and assembly
    -front axles can be reused?
    -DCCD controller optional but recommended
    04 JDM Sti 6 speed:
    -transmission
    -driveshaft again
    OR
    -some seem to be DCCD and others non-DCCD with Viscous LSD
    05 USDM Sti 6 speed:
    -transmission
    -driveshaft
    OR
    -hubs or Stubs? Not clear on this one for the front but it seems there is extra that needs to be done with an 05
    05 JDM Sti 6 speed:
    -transmission
    -driveshaft
    OR
    -Again not clear, but seems some come without DCCD
    06 USDM Sti 6 speed:
    -transmission
    -driveshaft
    -Stock R160 can be used without changing the gear ratio due to change in 06 that makes the ceneter diff a 1.1:1 vs the old 1.0:1
    -stock Axles can be used on rear due to no need to change the rear diff
    -front...replace the Stubs with either WRX stubs or some other...not clear on this either, but it seems that some stubs can be ordered along with seals and clips that retains the WRX front Axles, hubs, etc?
    06 JDM Sti 6 speed:
    -transmission
    -driveshaft
    -no clue
    -no clue
    -no clue
    07 USDM Sti 6 speed:
    -transmission
    -driveshaft
    -no clue
    -no clue
    -no clue
  2. crashtke
    Reserved for future information.
