Modded injectors?
Discussion in 'Modifications & DIY how-to' started by mckenzietj, Jan 24, 2007.
  1. mckenzietj
    mckenzietj Member
    I've read posts where mods included "modded injectors". I assume these are modified stockers, can anyone describe what has been done to them to give them the higher flow rate?
  2. crashtke
    There is a cap on the end of the injector that can be massaged off of the tip...ok that just sounded bad...let me try again. You grind the cap off the end of the injector. If you imagine a hat, you would grind around the lowest part of the hat (closest to your ears) and the top just pops off. I have read mixed reviews about these. My impression is to go with d-werks as they are still pretty cheap at $217 after refund for your stockers. They also flow test each set.
  3. miloman
    actually the deatschwerks modded injectors (http://www.deatschwerks.com/) are supposed to be awesome... originally, the only offering was capless, like crash just explained... however they now offer them with replacement caps... thus, u can buy them with predetermined flow rates (http://www.deatschwerks.com/subaru.htm) ... if they are flow tested in huge batches and the closest flowing ones are grouped together and sent to the customer... i will be using these on my new setup... slowwrx is running these with his GT30R... according to scott, these are probably the best matched injectors in the market right now... enabling you to get the maximum possible timing
  4. JJang12
    JJang12 Active Member
    I have deatschwerks' 850cc version. They work just like stock ones. Smooth idle and solid flow up top.
  5. slowwrx
    If you bring them to the install day I will mod them for a 6 pack of import beer
  6. Cool_____
    I modded mine. 820 cc's. RCEngineering flow tested mine and they came out 819, 820, 820, 821.
  7. jt money
    damn you cant beat that.
  8. goixiz
    goixiz Active Member
    how bout stock OEM 2.5L engine injectors
  9. WRX-WRC
    they are the same as STi injectors, so it can be done.
  10. 1ll-WRX
    wow...what kinda beer we talking?....:ddirty:
  11. goixiz
    NOT FOR MODDING BUT TO USE
  12. slowwrx
    New Castle or Guiness works
  13. miloman
    these are capless right?
  14. WRX-WRC
    no need to use caps there buddy, you dont need to get snippy.
    your original question makes no sense, you already have stock injectors, what is the question?
  15. miloman
    i believe the 2.5 liter wrx injectors are top feed whereas the STi injectors are side feed
    i dunno about the other 2.5 motors
  16. WRX-WRC
    Hmm, if thats true, then i retract my statement.
  17. EJRex
    EJRex Member
    ^^ it's true, with USDM models. I'm using a set of 800cc modded blues with my 20G.. never had any issues, and they're relatively cheap compared to aftermarkets.
  18. Cool_____
    Oh snap you like those too? Everyone thinks I'm crazy when I say those are my favorite beers.
  19. Brian
    Brian Active Member
    If you're worried about messing up your injectors modding them, I still have a stock set of STi injectors for sale.
  20. slowwrx
    Ill be happy to do anyones injectors that wants them done, just bring them to the dyno day.
    Matt
