Motor mounts
Discussion in 'Modifications & DIY how-to' started by suomi82, Sep 15, 2015.
  1. suomi82
    suomi82 Member
    Anybody ever needed to remove sway bar to get the lower bolt off? For the life of me I can not fit a socket with an extension to get that bolt off. It won't fit straight and would strip the bolt. Car is a bugeye with a STI sway from the looks off it, all the DIYs I've seen have more than plenty of room between subframe and sway, however my piece of shit obviously does not.
  2. Justin V
    Justin V Member
    Stock sway should have a bend, even my whitelines I can get the socket on the nut and then put and extension on it.
  3. suomi82
    suomi82 Member
    That's what I saw on all thr DIYs, bend on sway, this looks just like the ones on STIs but it blocks the bolt. Ended up taking it off.
