Motor stop turning randomly.
Discussion in 'Modifications & DIY how-to' started by Herbandiscipline, Jan 30, 2013.
  1. So I was driving home today during rush hour and my car dies on me as soon as I slip into neutral at a light. I turn the motor over again and its fine. Get to another light and it dies on me. This is probably after driving in traffic for 10-15 minutes.
    So I try to turn the car back on, get a loud buzzing noise and the console lights up.. I had my Starter, battery and both terminals replaced a few months ago.
    After ten minutes being on the side of the road I try to turn the engine one last time and it finally turned over and I made it home. The car didn't produce any CEL codes. Trying to figure out a list of things this could be. I'm hoping its just the terminals on the battery. I have a road trip in a week.
    Sorry if this is a mess im having a hectic day and im sorry if this is in the wrong place.
    sounds like a possible vaccuum leak. but the buzzing sound doesn't add up
  3. integroid
    Starter could be going bad again. Did you get a Subaru starter or an aftermarket?
  4. Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 6_0_2 like Mac OS X) AppleWebKit/536.26 (KHTML, like Gecko) Version/6.0 Mobile/10A551 Safari/8536.25)
    I got a 06 sti starter it was used. By the time I got home it was too dark to look under the hood. I am going to see if I notice anything. Luckily I had plans to see Allpro on Tuesday.
  5. b reel
    two grounds on the intake are the first place I'd look after the battery, starter and alternator.
  6. sikwrx04
    sikwrx04 Member
    I had this same issue...well almost, but do you have an aftermarket inlet?
  7. b reel
    goes back to the vacuum leak Matt mentioned, replace the o-ring on the MAF sensor
  8. Wirelessly posted (Mozilla/5.0 (iPhone; CPU iPhone OS 6_0_2 like Mac OS X) AppleWebKit/536.26 (KHTML, like Gecko) Version/6.0 Mobile/10A551 Safari/8536.25)
    I believe it does actually. It would of come on the car when I bought it.
  9. So I turn the car on with no problems this morning just to let it warm up, and it dies after 4-5 minutes. No buzzing noise when I try to turn the motor. The motor starts turning but can not successfully turn. Going to try and get some o rings. I looked around trying to find out what o-ring fits onto my car. It seems like 2mm x 28mm was the most mentioned fitting. Does anyone know from experience?
