multi-quote.
Discussion in 'Meta' started by Matt, Feb 25, 2007.
  1. Matt
    if I want to do the multi-quote in a thread, I click the (+), click the second (+), and then click the (quote) button, and only the post where the (quote) button shows up.
    :confused:
  2. jt money
    dunno lets see
    edit your right i cant get it to work either.
  3. Alex
    Yeah I'm well aware. With the latest vbulletin release Im finding a few things that we're behind on (multiquote for example). I will be reworking a good bit of things soon. Sorry for the inconvenience.
  4. Matt
    no inconvenience, I just get a higher post count!!
    :D
  5. blindfold
    blindfold Active Member
    I use Opera and copy/paste with the back button(which is simply hitting the "z" key or hold down right mouse button+click the left at the same time) seems to be easy enough
  6. Alex
    If it were to be working the way to properly use it is to select the threads you wish to quote and then hit the post reply button.
  7. Alex
    Just fixed MQ :D
    ak
