My 04 STI Build 630whp
Discussion in 'Member Journals & Project Build Stories' started by jkb2198, Nov 3, 2013.
  1. jkb2198
    jkb2198 New Member
    This is a Top speed motorsports build other then the suspension. Me and a coworker did all the suspension work ourselves.
    Motor:
    GSC S2 Camshaft
    Tomei Timing Belt Guide
    NGK Iridium IX
    Ferrea Valvle Guides
    Ferrea Springs and Retainers
    Over Sized +1mm
    Manley Pistons
    Manley turbo tuff rods
    ACL race bearings
    Pinned and O ringed the deck
    Oil galley modifications
    Balanced and Blueprinted
    Updated Oil pump
    Bolt ons:
    Cosworth Intake Manifold
    Aeromotive fuel rails and fuel pressure regulator(top feed all an fittings)
    TSM Spec Bosch 2000cc injectors
    Act 6 Puck clutch w/HD pressure plate and lightened fly wheel
    Walbro 485 LPH E85 pump
    Torque solutions motor mounts/trans mounts/and pitch stop
    Fluidampr Engine Damper
    Invidia Equal length headers Ceramic coated titanium
    Ams GTX3582r turbo kit, test pipe (ceramic coated) 44mm Tial wastegate and tial hotside ceramic coated titanium
    Header wrapped and ceramic coated the ams two piece down pipe
    AMS Crash bar
    AMS FMIC with 2.5 inch black piping
    AMS small battery kit
    Perrin coolant Overflow
    Crawford AOS V2
    Turn in concepts composite TGV's
    Kartboy short throw shifter
    Suspension:
    Drive shaft shop one piece aluminum drive shaft
    White line steering rack bushings
    White line front and rear sway bars and sway bar mounts
    White Line Anti-lift kit
    White line Front roll center adjustment kit
    Kart boy botox subframe lockdown bolts
    White line Adjustable lateral links
    Dba 4000 rotors in front and rear
    Hawk hps ceramic pads
    Pictures coming and dyno results soon. Two maps. A 22psi map and a 28psi
    image hosting websites
  2. SonicBoom
    SonicBoom Active Member
    Sounds awesome....
  3. Mike@TSM
    Mike@TSM Member
    This car made some awesome power and came out really nice! We are very happy with the results - enjoy the car my friend!
    I will have some pictures to add later on as well.
  4. jkb2198
    jkb2198 New Member
    Please send me an email mike of the dyno results. Placed second at forges dyno day :)
  5. Mike@TSM
    Mike@TSM Member
    Nice!
    It's on it's way shortly.
  6. flat_4ATL
    flat_4ATL Member
    nicely done!!! looks good! i cant wait for bigger injectors and more boost for a retune
  7. superhawk28
    superhawk28 Member
    What came in first?
  8. jkb2198
    jkb2198 New Member
    Z06 vette
  9. WRXbryanATL
    WRXbryanATL Member
    callaway z06
