my brake light is on
Discussion in 'Introduce Yourself' started by mattprzy, Oct 25, 2005.
  1. mattprzy
    mattprzy Active Member
    Sep 24, 2005
    1,113
    0
    about 90% of the time while I am driving, my e-brake light is when it should not be. It turns off sometimes when I accelerate really hard. It dosn't seem to damage anything other than the possiblity of giving the light that is lighting up the brake light a shorter life span.
    Has this happened to anybody before? Should I worry about fixing it?
  2. Weapon
    Weapon 90lbs of dynamite
    Supporting Member
    Jan 29, 2005
    6,875
    0
    check your brake fluid :wiggle:
  3. miloman
    Feb 3, 2004
    12,774
    1
    i have that issue since i tinkered with the wiring... do u have a turbo timer? if so, check the wiring to make sure nothing came loose
