my car is too hot, yeah baby
Discussion in 'Modifications & DIY how-to' started by Brian, Aug 7, 2006.
  1. Brian
    Brian Active Member
    Actually not so good. My engine bay is so hot, I think it's vaporizing the meth in the washer tank. It's been going much faster than what it should. I've already got the turbo hot side and some of the dp shielded. But everything on my car has overheated at one point or another.
    I'm starting to think about
    1. venting hood (evo style, but to the sides of the scoop)
    2. heatshielding around the meth tank
    3. phenolic spacers for the intake, who makes these?
    4. extra hood scoop for the intake, ala early 300zx
    5. gasp, even a fmic
    6. oil cooler
    7. RCE cool brake kit
    8. maybe a radiator, not sure if it's needed now that thermostat is fixed
    Any opinions/experience on these mods? Overheating ruined my last track day...
  2. clemsonscooby
    clemsonscooby Active Member
    Go with a big fluidyne or similar brand. I've heard they do wonders for cooling. Keep the TMIC. Adding the FMIC in front of the radiator doesn't too much to help cool your engine bay. Sure it does give you a cooler intake charge, but your methanol will still be evaporating away. Oil cooler would be a good option as well. I would play a little with some "custom" brake ducting as well.
  3. miloman
    have you considered a trunk mounted meth tank? im sure hot meth loses some of its chemical intercooling abilities
  4. calmnothing
    the phenolic spacers and coolant bypass mod (check scoobymods on how to do this) should help. Most people say that the intake manifold is warm to the touch instead of seering hot after this mod.
  5. Trey
    Trey Active Member
  6. Brian
    Brian Active Member
    I'd be afraid of the coolant bypass mod since I like playing on the ice/snow. Meth crystal aren't good for ya.
    Thanks for the phenolic spacer link and pointers so far. If I could find a good way to fill the spec c trunk tank I'd go that route with the meth. I hear it's a PitA.
    Isn't Mahdavi Motorsports a site sponsor? They're the local Hondata dealer...
  7. miloman
    veck has the spec-c tank... might wanna PM him and see what he thinks
  8. Cool_____
    Do what SS told me to do (and I need to get it done). Get a turbo blanet and make a 'diaper' for the meth pump and tank. Won't be pretty but it'll do it's job.
    I know how you feel. My hood is HOT HOT HOT to the touch when driving.
  9. Brian
    Brian Active Member
    How do you touch your hood when driving?
  10. pEd
    ^^ go go Gadget Arms :)
  11. Cool_____
    LOL I meant as soon I pull in and touch the hood it is already hot.....sorry for the confusion.
    :keke:
  12. Brian
    Brian Active Member
    heh heh. So does anyone know of a hotrod type bodyshop that could add extra scoops and vents to a stock STi hood?
    Also, a graphics shop for some custom graphics. I'm looking for a bit of NOPI bling too.
  13. Cool_____
    We do our own graphics and Sakari does as well. Hit me up if you are interested.
  14. Alex
    Steven is also running the spec c meth thank. And nopi bling would be pimp, so long as it says WRXatl everywhere!
  15. pEd
    Don't forget the BMW style vents on the side of the front fenders.
    That would really help get the heat out yo engine bay!! :keke:
  16. Cool_____
    Just drill holes everywhere for the bee hive look....lol j/k.
    I am seriously wanting the CWest CF hood for heat venting but alas no money.
  17. Brian
    Brian Active Member
    lol, my 96 CRB900 came with a bunch of holes drilled everywhere, esp. the lower fairing. Not what I'm after.
  18. onemoresti
    onemoresti Member
    I just covered my meth tank with some heat shield made by thermo tec.
    I'm sure there is enough to do one more tank. It's not the purdiest thing but it does work. Before I could see the meth boiling after short drives.
    You can have the rest of the roll if you want. I can't really use it for anything else.
  19. clemsonscooby
    Yeah, get yourself a nice "pull my finger graphics" FF style.
  20. crashtke
    http://www.thepartsbin.com/sitemap/subaru~engine_oil_cooler~parts.html
    There are some oil coolers out there that you can get into that won't cost a fortunre. But not sure that they are really gonna keep your bay cool. Another option is getting some form of venting going on in the engine bay like some of the hoods I have seen that have a vent up front to let radiator heat out. I think seibon makes a hood that has a vent up front as well as the scoop.
  21. Cool_____
    The hood with the vent in front like the Evo has is the WRC style hood.
  22. Brian
    Brian Active Member
    Do I want to know what "pull my finger graphics" FF style is? Maybe color-shifting paint with tribal patterns and lots of sponsor stickers... ;) (kidding)
    It doesn't make sense to vent the radiator then scoop it back onto the fmic. Something like this would work
    windshield
    | <turbo vent>...............< vent>
    | .............<tmic scoop>
    |<ca>
    front of car
    ca - cold air scoop
    ASCII ART FTW!
  23. Cool_____
    That is essentially what the Cwest style hoods do. They have 3 vents on each side of the hood.
    My only concern is rain and the water pouring on top of the intake but if I build my box like it should be it'll all be covered (the intake filter that is).
    Brian you just have to make darn sure that if you mod your stock hood, that the shop knows what they are doing. I imagine it would be WAY too easy to screw that thin sheetmetal all up.
