need help sway bar
Discussion in 'Modifications & DIY how-to' started by para83, Jun 5, 2008.
  1. para83
    para83 Member
    Im about to buy some whiteline swaybars the front one is from an 04 wrx and the rear is from an 02 and i just wanted to make sure these will fit my 06 wrx
  2. should be interchangeable unless from a wagon,then front is slightly different.
  3. ScoobyMike
    ScoobyMike OG Mod
    ask king or WJM or SS
  4. Sparta
    I think the brackets for the rear are different. I know when I used an 06 rsb I had to change the mountain brackets too. Front shouldnt be an issue though.
  5. SubiNoobi
    SubiNoobi Supporting Member
    The front will be fine. Even sedan and wagon bars will interchange with the help of spacer washers.
  6. FACE
    I would think they will fit fine...
