I need the assistance of someone that can compression check my motor. If you are that someone i can provide beer or other goods for your help.
We can do it for you tomorrow. $60.00 Let me know if that works for you. Throwing it out there for an option for you. Take care!
per suggestion of WJM. recently got a cel for cyl 1 misfire and one that was pfffe but I was unable to figure out what that one meant. My car seems to make power fine but has a very harsh idle while warming up and that is usually when it throws the code. The code hasnt be thrown at any point in time under a hot start.
Wirelessly posted (My Phone) I know I saw you on the test drive, so I have to ask...is the car not under any warranty from the dealership?
Its got subarus gold extended warranty or what ever you call it. WJM seems to think that they probably wont cover it. This is a real bummer seeing as i've had the car less than 3 months.
Is it modified? I'm guessing it is if you think they won't cover it. If its stock, I'd take those fuckers to court.
