Need help!
Discussion in 'Modifications & DIY how-to' started by suby113, Apr 10, 2006.
  1. suby113
    suby113 Member
    I have a Greedy profec b spec 2 and I need to know if any one knows what the settings should be for a wrx with stock turbo. I have an upipe and down pipe and cat back and an injen intake. I need to know what the set boost, Gain, and start boost setting should be if possible. HELP
  2. Alex
    I havent the slightest idea, hopefully someone will chime in.
  3. moose
    I'd strongly recommend running this past a tuner to see how good of an idea it is if you're running stock engine management...
  4. suby113
    suby113 Member
    haven't had an issue yet, I have had it on the car for a while now, I was just wondering if maybe someone was using one also, and if so what was there set up, I believe i have it set according to my mods, was just curious though.
    Thanks,
  5. jt money
    i would not exceed 16psi in third. thats about all the stock ecu will handle. i used to have a mbc on my stock ecu. never played with the profec 2. hope this is a good starting point.
  6. suby113
    suby113 Member
    cool thanks, I already have it set for 16psi and it won't boost over seems to run pretty strong, I will get tuned when I upgrade the turbo, injectors,etc. Which I plan too, One question I do have is why did my engine lite come on when I put in an upipe and is there a way I can turn it off, the code states that car is running below catalyst level. I know I don't have any cats.
  7. jt money
    yes there are cel fixes for this problem. maybe someone will post up thats more knoledgable about hem.
  8. moose
    Please do some datalogging and see what your A/F ratios are as you're boosting. I'm betting you're seeing some pretty serious boost on a lean mixture, and while the car obviously runs ok so far it's not necessarily GOOD for it...
  9. suby113
    suby113 Member
    Even if I am boosting under 16 pounds it still will run lean? I thought you could boost stock wrexes to 16 pounds no problem? Or is that not true?
  10. moose
    Pounds of boost is not 100% related to do the mixture. On a stock 04/05 the enrichment delay causes the car to run quite lean under boost before it switches into open loop fueling. On a stock car it can be 2-3 seconds after you stomp on the throttle; if you're boosting faster/harder through the use of a boost controller you're exacerbating the issue.
    You really oughtn't mess with any of this stuff without doing some type of logging to see how it affects things.
  11. suby113
    suby113 Member
    ok cool thanks for the info
    Moose how much does it cost for a regular WRX to get tuned or have the utek reprogrammed to my mods until I upgrade turbo etc?
  12. brettedmonds
    brettedmonds Member
    i think if you use ecutek its around 850 or so for the reflash and a couple hours of dyno or road tuning depending if you use s.s.(subaru of gwinnett) or doug (topspeed). both are great tuners. scott mostly road tunes and then dynos and doug dyno tunes and then road tunes. i guess youll have to pick on who seems to be sexier to you
  13. miloman
    in general it's $120 per hour
  14. suby113
    suby113 Member
    is ecutek the stock ECU?
  15. moose
    Not sure about Utec cost, but Ecutek runs $850 generally as brett said. Another option--which I personally prefer--is the Cobb AccessPort which you can score for around $500 used and will give you some rather decent off the shelf maps you can run for as long as you want (you might want to see if the Injen intake is ok with their supplied maps though). You can also spend another $300 on top of that to get it professionally tuned ala Ecutek.
    Ecutek reprograms the stock ECU. Same for Cobb AccessPort/ProTune. Utec is a piggy back add-on.
  16. suby113
    suby113 Member
    :wiggle: Thanks Guys!
