Hi I am pretty new to the forum if you have read some of posts you will know I've had some issues with some new wheels I purchased. Long story short I had to get large spacers on the front wheels to clear my brembos. In order to run the spacers I had to get the arp wheel studs. I decided to get them for the front and the rear because the tire place that installed the wheels stripped out to of the lugs on the rear. They said they would replace them but after their track record I thought I would do it myself. The problem is last night when trying to change out the rear studs I broke the abs ring. So now if I understand correctly I need to get a new one and pull the hub and I will also need a new wheel bearing? If anyone knows a easier way to do this your advice :bowdown: would be greatly apreciated. Also who might have the abs ring and wheel bearing instock. I am going to try to call around this morning but I have a ton of meetings. Derek Murray
Wow! That sucks. Go to the stick in the DIY thread that has the service manual. You should start looking for the way to solve your problem there. Then start thinking about getting a new set of wheels.
