Need Tires!
Discussion in 'Introduce Yourself' started by SolutionBuilt, May 15, 2006.
  1. SolutionBuilt
    SolutionBuilt New Member
    Hey guys, anyone know where I can get a great deal on some tires? Thanks in advance!
    Respectfully,
    Jesse
  2. scuby drew
    scuby drew techos ftws!!EEEE
    pick up a set of used stock re92's and inflate them to 58 psi on the fronts and 56 in the rear. haha, well thats atleast what i did, couldnt beat it for 20 bucks
  3. bigb996
    i paid 325 shipped for 4 toyo proxes fz4s from treaddepot.com
  4. kingwrex
    kingwrex Supporting Member
    WWW.TIRERACK.COM HAS A FEW GOOD DEALS. IT ALL DEPENDS ON WHAT YOUR PRCE RANGE IS FOR TEH MEANING CHEAP
  5. SolutionBuilt
    What's the widest tire that I can put on stock 2005 rims? Thanks.
  6. clemsonscooby
    clemsonscooby Active Member
  7. BrianGT
    hankook rs-2 tires are cheap and good.
    Brian
  8. Brian
    Brian Active Member
    What ever happened to that tire shop who was going to sponsor the site and buy us all dinner?
  9. miloman
    they never followed up :dunno
  10. WrxCrazy
    WrxCrazy Active Member
    thats messed up.. btw for stock i would go with 45 or 55 not more then that.. that is what the subaru rec'mends
  11. flip
    flip Member
    I'm going to need new tires soon too, any suggestions on better tires than my stock potenza's? I've heard there are some others that are slightly cheaper but way better on performance. ANy ideas what those would be?
  12. I'm running Eagle F1 GSD3...some soft sidewalls. I've heard the Toyos are exactly like mine in performace (prob better) and it has stiffer sidewalls. The wheels really shine in how much grip they get in water!
  13. suby113
    suby113 Member
    Discount Tire direct!
  14. Doug
    Doug New Member
    DT,
    Are you the guy that recommended I check out WRXAtlanta out on the LegacyGT site?
    D
  15. xjenjenx
    xjenjenx Member
    i just got some cooper tires yesterday.
  16. bigb996
    i truthfully wouldnt go wider than 235. you could go a little bigger probably.
  17. SolutionBuilt
    Ahh, thanks. How about a set of 18" rims? Can I drop some 225/40/18's without rolling the fenders?
  18. slpymnky
    slpymnky Member
    Yup. I have 225/40/18 tires on my car and I have TEIN S-techs and my car is fine.
  19. rsxkiller
    rsxkiller Member
    Edgeracing.com for cheap tires check them out and great customer service. As far as replacement for stock Potenzas RE070 I would look into Toyo T1R or Falken Azenis 615 or Hankook Z212 RS-2 all great tires and will last a little longer than the stock ones hope that helps.
  20. BelvnAWD
    :werd: Seriously great prices...
  21. goixiz
    goixiz Active Member
    width of tires depends on the width of rims not size
    7" rims best fit 215s (I wont go any higher than 225s)
    There is optimum and allowed so if you go passs that you are on your own
