need turbo...want about350
Discussion in 'Modifications & DIY how-to' started by youradumb1, Jan 4, 2006.
  1. youradumb1
    youradumb1 Member
    i want about 350 before nos..plan on getting front mount also...what should i do?
  2. moose
    VF34 would easily get you there if you're talking crank hp... if you want wheel hp, probably an 18 or even 20G.. not sure about those though!
  3. KingofSiam
    KingofSiam Member
    I'd go 20g for those kinds of numbers on a wrex. I think with an 18g you might have to push it.
  4. Weapon
    20G would do it. oh and a new tranny ;)
  5. yerrow
    yerrow Active Member
    we only refer to WHP. crank HP means nothing
  6. WRX-WRC
    18G would be close, 20G would be a defininte; however, you're going to have crazy lag w/o nitrous on a 2L.
  7. moose
    Well pardon me then. :pssh:
    Anything else 'we' do that I should be aware of?
  8. Weapon
    yea moose!! geez!!
  9. Tray@topspeed
    Tray@topspeed Member
    20g with meth you should have a lot of fun.
  10. moose
    We can start a betting pool on whether the tranny, clutch or engine will go first. :naughty:
  11. yerrow
    lemme rephrase, we may as well only refer to whp since no-one locally really has the means to record a true crank horsepower.
    we may as well also only refer to WHP since thats the power thats actually making it to the ground
  12. youradumb1
    youradumb1 Member
    what to use and still run stock tranny with act clutch and fly?
  13. stinny
    stinny New Member
    If you want around 350whp you need the 2.5L shortblock unless you have a 2.0LJDM engine. The tranny will have to be rebuilt to handle that much power. As far as turbos, I would go with a 20g or even a SZ49.
  14. miloman
    personally, i'd go with a turbo that has a wide power band over one that makes a lot of peak power
  15. KingofSiam
    KingofSiam Member
    Which would be...
  16. monk
    ... a 2.5L bottom end! :p
  17. miloman
    i love the response of my super 16g... makes peak torque under 3700 and pulls all the way through... numbers have varied on different dynos (topspeed and sog) but the max i got was ~277whp and ~277 wtq at 21 psi peak boost (with a taper at higher rpm) at sog... feels great with the top mount... theres a guy on nasioc who made 307whp on his super 16g with a FMIC at only 18psi i believe... trying to get his plot to find out how laggy it is with a FMIC
    my other option was a vf34 but i decided to go with the uniqueness of a super 16g... people have been trying to compare both turbos... theoretically the super 16g should make more power than the vf22 and at the same time out spool a vf 39...
  18. youradumb1
    youradumb1 Member
    so milo ...u say 16g ....ok than...what do u think ill pull hp wise with 16g,turbo back ,up pipe,pully, front mnt?oh and turbo port and polish?..
  19. slowwrx
    Thats not true at all, just because everyone on the internet tells you that you cant make 350hp on a stock 2.0 doesnt mean you cant.
    If you get a GT30r you can make 350hp on pump and 400hp on race gas.
    I will be the first to admit that the stock 2.0 is not going to live very long at 400hp. But my motor has been fine at 350hp. If you have more questions about how to do it on the stock bottom end just let me know. If you buy an AEM to run the car I will even give you my map.
  20. youradumb1
    youradumb1 Member
    cool..thanks...yeah send me the info on what to do and ill check it out...im done building my bmw so im ready to finish the wrx.
  21. GTscoob
    I'd think that a GT30R with a lowish A/R on a 2.5L engine would make 350+whp and have a nice broad powerband.
    Matt, how laggy is your GT30R on the 2.0?
  22. slowwrx
    I see full boost by 4500 rpms, I will see if I can find one of my dyno charts to post, I have been doing a little road tuning lately and it seems to be making more power.
    I have a gt30r with a precision .48 backside, which flows more like a .68 from garrett
  23. stinny
    stinny New Member
    How long do you estimate that a 2.0L motor will hold this much power as a daily driver? IMHO If you want that much power why not get a short block that can reliably hold that power. The larger displacement helps to spool the larger turbos. I would like to know more info about your setup becasue I wanted to convert to a 2.5L in August.
  24. slowwrx
    I suspect that a properly tuned 2.0 would last a long time at 350hp, its not the hp that kills motors(or in the case of a stock 2.0 rods) its torque, I can get the motor to make less torque, you just detune it a little.
    Here is my current setup
    Stock 2.0
    GT30r with a .48 backside
    Custom Turbo Kit by Batlground Engineering
    Borla Hush exhaust
    Modified injectors
    255lph fuel pump
    TGV deletes, which make almost no diffrence(dynoed back to back)
    Perrin Front Mount Intercooler
    Tial 38mm wastegate
    Tranny
    PPG straight cut 1st-4th stock 5th
    ATS twin carbon clutch
    Thats pretty much all the important stuff
    car makes 344hp at 18lbs of boost on pump gas
  25. stinny
    stinny New Member
  26. slowwrx
    Yeah, thats it.
    No, I did buy the gearset from andrew. But I rebuilt the box myself. Ill post up the dyno chart as soon as I find it. I cant remember the exact number off the top of my head.
    Matt
  27. miloman
    with deadbolt's super 16g u should make over 300whp... Magman on nasioc put down 307whp @ 6300 rpm and 266wtq @ 5300 rpm at just 16.5 psi, 91 octane at 4400 feet!!!... thats pretty impressive to me... im making less cuz of my TMIC... so im now considering a front mount too
  28. youradumb1
    youradumb1 Member
    thats it then 16g with front mnt it will be
  29. slowwrx
    if you are on a tight budget, then I would go with an 18g, I had one on my car and it was awesome. It trapped at 118 on a slipping clutch, it had great midrange power and your only giving up 150-200rpms of spool time vs the 16g.
    If money is not as big an issure then I would go with a rotated setup but use a Precision 2871 instead of the 30r. You will get quicker spool up and you should still make very close to 350 on pump gas.
    The rotated turbos are better because there are no space constraints, you dont have to squish the compressor and exhaust housings to get them to fit.
    Nobody has done the 2871 on a subaru that I know of yet, that would be the hotness. If you want help let me know.
    Matt
  30. SonicBoom
    SonicBoom Active Member
    "about $3.50...thats what he said... Damned lockness monster!!!!"
  31. youradumb1
    youradumb1 Member
    hey thanks matt ,i will need some help when the time comes ....
