new code
Discussion in 'Modifications & DIY how-to' started by sleeper31204, Nov 9, 2007.
  1. sleeper31204
    sleeper31204 Member
    P0244~Wastegate control solenoid valve malfunction (high input)~
    how to fix, i may have an exhaust leak below uppipe, could this be hurting anything to do with this?
    thanks
    -William...
  2. lostinthewoods
    Think this is the lovely boost creep code. Switch to a LWG map should solve the issue.
  3. sleeper31204
    sleeper31204 Member
    S.S. tuned for 19 psi, this went off at 17 in forth, and again in fifth, not sure the boost psi tho.
  4. nsvwrx
    nsvwrx Active Member
    Talk to SS.. he stands behind his work...
  5. kingwrex
    kingwrex Supporting Member
    I Just Recently Had A Wrx Throwing That Same Code. It Ended Up Being A Vacume Connector That Dryrotted From Heat And Crumbled To Pieces Causing A Leak. It Was The Line From The Wastegate Solenoid Valve Going To The Turbo.
  6. sleeper31204
    sleeper31204 Member
    i got to take her to the shop this week for some work, ill get them to check that line out, thanks man.
    -William...
