New motor
Discussion in 'Modifications & DIY how-to' started by 04subiwrx, Apr 7, 2009.
  1. 04subiwrx
    04subiwrx Member
    I was on craigslist last night and saw someone had posted a free wrx motor with engine stand. Went and picked it up last night and the engine stand is brand new and the motor has about 75k on it. Thinking of doing a Cosworth 2.2 stroker kit. Just wondering if anyone has any input. I would like to run a rotated 30r. Or should I just go with forged internals?
  2. yerrow
    yerrow Active Member
    while its out and an extra, may as well go on and do a full build
  3. FACE
    Nice find man!
  4. Bug-Rex
    Bug-Rex Active Member
    Lucky! Pics!
  5. XanRules
    XanRules Active Member
    O_O
    full motor, or just the block?
  6. ZenMotors
    ZenMotors Member
    Nice find!
    I always miss the good stuff. :)
  7. slowwrx
    Free is nice but the 2.0 liter blocks don't really make that great of a motor even built. There isn't enough support around the cylinder walls and they tend to crack the bores or come out of round.
  8. calmnothing
    Sell it and buy a 2.5 block to build.
  9. WRXCoupe
    WRXCoupe Active Member
    Get a 2.5 shortblock^
  10. 04subiwrx
    04subiwrx Member
    Its a whole motor. Heads, sti oil pan, everything. I kind of want to do a built 2.0 just to be different. Everyone always throws in a 2.5. I know why but I still want to stick with the 2.0 platform. I will post pictures later tonight.
  11. Cool_____
    Lucky you.
  12. Kokopelli
    There is a reason people spend the time and money to build a 2.5. Seriously I wouldn't spend the money to build a 2.0. I have given away plenty of 2.0 short blocks because they have no value. The real score you have is the heads and the engine stand. The heads can get you 300 in stock form if they are in good shape and with just a little work can be improved greatly.
    To me the ej20 is only worth its weight in aluminum at a recycler.
  13. Sparta
    just curious... at what power level would you recommend building the wrx heads before advancing?
  14. Kokopelli
    Once you get to a 20g sized turbo on a 2.5 with ej20 heads you start missing out on some real power in the upper rpms without head work.
  15. XanRules
    even the harness?
    If so...hmmm....
  16. AtlxPat
    AtlxPat Active Member
    how strong are the 2.5l in the 06-07 wrx?
  17. GTscoob
    If you want to build a 2.0, the 205 is not the best place to start.
    Good find, it's gotta be nice just to have the motor so you can take it apart and learn how to rebuild from scratch
  18. Cool_____
    :unamused: No credit for the good ol EJ205 eh.
  19. Jake
    Iirc they are the same block as the sti's just no forged internals. They're the previous year model legacy motors.
  20. Cool_____
    They are forged rods in the 2.5L WRX I believe. Higher compression than STi 8.4:1 vs 8.2:1 and tamer cams.
  21. Jake
    Ok yeah that sounds right I know they have avcs tho.
  22. Cool_____
    Yes they do.
  23. 04subiwrx
    04subiwrx Member
    Someone threw me a offer for 300 for the motor.. Should I take it?
  24. slowwrx
    If it runs Ill give you 500
  25. 04subiwrx
    04subiwrx Member
    The guy said it ran great when it was pulled. But that is taking his word for it. Anything I can do to check it out with out actually installing it?
  26. 04subiwrx
    04subiwrx Member
    I know the heads have to be worth at least 300
  27. Mike@TTR
    Mike@TTR Active Member
    Depending on the year of the heads they could be worth 300 alone. If Slowrx is offering 500 I would take that offer though :)
  28. Jake
    I think I am gonna get rid of my 2 2.0l shortblocks. I am just gonna maintain the current motor in the L. Both of mine are known bad but could be use to make one good short block. Perhaps the buyer of your motor would want to pick up mine super cheap for parts as well. And yeah the heads alone are worth at least 300 if not more. Depending on year/mileage
  29. 04subiwrx
    04subiwrx Member
    I think I would rather hold onto it than let it go for 300. I should be able to get more. Hopefully slowwrx wants it.
  30. XanRules
    I'll take the engine stand :3
  31. Cool_____
    I paid LiquidForce $300 for the good set of shimless WRX heads he had so your entire engine is worth a good $500.
  32. Cool_____
    What year car the engine come out of?
