1. Where do you live? Roswell 2. What do you preferred to be called (not your username)? Ivan 3. What do you drive? 2009 2.5i Hatch DGM (Dark Gray Metallic) 4. How modded is your ride? Just turned 1000mi but have done the following mods: Debagged iPod Interface Black Aero Carbon Lip STI Pink Springs Rota Tarmac 2 wheels (17x7.5) Yokohama ADVAN AD07 tires (225/45/17) STI Grille (STI emblem removed) Perrin 25mm Front Sway Bar (will install this week) Perrin 22mm Rear Sway Bar (will install this week) Perrin end links Front & Rear 5. Where do you usually by parts? Mail order (online vendors), EBay 6. Do you visit any other local boards? http://www.atlantascca.org/ http://www.soloatlanta.com/ 7. Show, Go, or Stock and staying that way? GO (Handling) 8. Do you wave to other wrx's when you see then coming towards you? Yes 9. Where did you find out about WRXatlanta? Saw a window decal a number of years back while at a AutoX Regards,
Welcome, thought all the 914's rotted away years ago. Check out our G2G's and come out to the Dyno Day. Would like to see what a new NA puts to the ground.
Welcome to the board Ivan from another NA guy. You should post pics of your car because I have thought about trading mine in to get one just like yours.
Thanks. Yeah most 914's have rusted away, mine is pretty solid though. I will check out the G2Gs and have been thinking about the Dyno Day. I've seen dynos for the new car and its in the low to mid 130s in both HP and TQ. I'm curious as well.
Drum roll please...... The best numbers of the three passes were: 125.09hp / 128.13ft-lbs Granted my car only has 1200 miles on it and a completely stock driveline. When the engine loosens up some more, I might get a little more power. Anyway it's a good baseline.
