New ride...Z31
Discussion in 'General Community' started by WRboXer, Dec 13, 2007.
  1. WRboXer
    WRboXer Active Member
    1988 Nissan 300zx turbo
    5 speed
    VLSD
    ~130K on the clock
    engine rebuild, new OEM clutch, new steering rack about 7K ago
    -17x9 shoes - Voxx Misano...I know they are cheap, but this is my project car.
    - 245/45/17 Falken zx512's
    -Tokico Illumina 5 way struts and 1" drop springs
    -A bunch of poly bushings
    -poly differential mount
    -3" Turbo back exhaust
    -Intercooler setup - using a MK4 supra intercooler
    -Short throw shifter
    -Cross drilled slotted rotors and new pads
    The car needs a lot of work, but I am going to do what I can when I can.
    EDIT!!!!
    Some stock parts... =/
    At first there was an empty space...
    this is what belongs in the space...
    some parts were installed...
  2. WRboXer
    SC61, mkIV side mount, dsm 450's, nistune are next....
  3. FACE
    Very nice man! looks clean...very clean
  4. SonicBoom
    SonicBoom Active Member
    Very clean... nice ride!
  5. Kokopelli
    I loved my z31's.
    The last one I had was an NA that I turbo'd and used my wrx tmic as a fmic. I tried to kill it by running 15psi on the stock NA block but it wouldn't die. Unfortunately I had to sell it because I could never get it to pass emissions.
    check out www.z31.com if you haven't already.
  6. BelvnAWD
    Really nice!
  7. pEd
    yummmy... that's a good looking car.
  8. WRboXer
    Thanks guys!:)
    Oh and ped, do you know Shawn Daughtery, drives an MS6? Well, i think he has mentioned me, my screen names on other forums is Swine. He has mentioned you on several occasions.
  9. GTscoob
    Nice. I've always wanted an older Z as a project car. You know that any RB engine will bolt right up to that chassis perfectly.
  10. TougeTuned
    TougeTuned Banned
    that series of cars always impressed me. Nice car man! i had its little cousing the 240sx s13 and couldn't kill it. my best friend has one of the rare z32's in the coco color that they only made ~400 of. even without the power of the turbo the z31 and z32 ere a blast to drive and still some of the best touring cars of they're time!
  11. ScoobyMike
    ScoobyMike OG Mod
    Nice ride buddy!! Hottness!!
  12. MrCoffeeATL
    MrCoffeeATL Member
  13. XanRules
    XanRules Active Member
    RB? :coolugh:
  14. Weapon
    looks good! especially for being 20 years old! :bigthumb:
  15. Deke
    Deke Active Member
    Looks good. Are these the ones with all-wheel steering?
  16. 1ll-WRX
    * RB20 - 2.0 L (1998 cc, bore: 78.0 mm, stroke: 69.7 mm)
    * RB24 - 2.4 L (2428 cc, bore: 86.0 mm, stroke: 69.7 mm)
    * RB25 - 2.5 L (2498 cc, bore: 86.0 mm, stroke: 71.7 mm)
    * RB26 - 2.6 L (2568 cc, bore: 86.0 mm, stroke: 73.7 mm)
    * RB30 - 3.0 L (2982 cc, bore: 86.0 mm, stroke: 85.0 mm)
    Additional Suffixes:
    * "D" indicates a double overhead cam as opposed to a single overhead cam
    * "E" indicates the engine is fuel-injected as opposed to carbureted
    * "T" indicates the engine has a factory installed turbocharger
  17. WRboXer
    Meh, dont need no stinkin rb, the stock motor is more then capable of handling anything im going to be throwing at it.
