New Shocks??
Discussion in 'Modifications & DIY how-to' started by slug, Jul 17, 2009.
  1. slug
    slug Member
    It has been a long time since I have slapped my TIEN S Tech springs on my car. I have always heard that you should, when modifying your car's height, swap out your shocks. I am usually of the opinion "if it ain't broke don't fix it" but was wondering if I would gain anything from swapping to a new set of shocks?? Also what is the average life span of shocks?
    Many thanks in advance for all info provided.
  2. Jake
    thats not the correct philosophy. when you lower a car you should ALWAYS upgrade the shocks. stock shocks are not meant to have that little travel. it puts more pressure on the cylinder than was originally intended.
    that being said, my old car has been whiteline flatout springs and stock shocks for ~100,000miles.
    but to answer your question, yes you should get some better shocks
  3. Weapon
    sounds like you should too
  4. Jake
    lol, its my old car. i don't own it anymore. and if i hadn't bought it that way i would've bought coilovers at the time. the shocks are in desperate need of replacement on that car tho....
  5. slug
    slug Member
    Ok, that being said, what should I look for when looking for new shocks? How will I know that the next set is built with lowering springs considered??
  6. SubiNoobi
    SubiNoobi Supporting Member
    All of them can handle a (at least a little) bit of lowering. The problem is that springs like the S-Techs lower too much and 1) severely reduce shock travel (which reduces the life span of any shock) and 2) put the suspension geometry in a less than ideal place.
    There are many springs that fit into this category, I'm not just picking on you, but the s-techs are some of the most popular.
    As far as better shocks go, there are a few options out there, but I cannot say if they will work well with the s-techs or not. KYB AGX, Koni, Tokico are some that I can think of. Tokico D-specs have been very popular lately, they are a full strut replacement and will work with any stocks style (non-coilover) spring. I have the koni strut inserts myself and would recommend them to anyone - they take a bit more work to install, but they are great shocks for the money.
    If you are going to get new shocks, look at some different springs as well. The s-techs are low and have soft spring rates, this combo means that it will put extra stress on ANY shock - forcing it to operate with little travel and potentially hitting the bump-stops frequently.
  7. FACE
    You may consider the RCE Yellow inserts. OneIguy has these and the install was not bad...
  8. GTscoob
    Are you thinking the Koni inserts on RCE yellow springs?
  9. yerrow
    yerrow Active Member
    1 vote for tokico dspecs
  10. RSConvert
    KONI YELLOWS!!!
    I have the tech s and koni yellow set up...I love it. I did and Auto X and the pass Mountain Run with them and it handled pretty well. It rides nice as a DD. I got a pretty good deal on them when I bought it a few months ago i think I got the Konis for 650 shipped.
  11. dundunskeert
    dundunskeert Member
    KYB AGX's should never be used over 1 1/2 below stock ride height. They will blow...
