so i finally got my new whiteline sways on. they are sweet! now i just need some tires tobe able to hang with the crazy turns i can make...
i felt the same way after puttin on my front and rear bars...i find myself throwing it into every corner i can find to do so safely and it just feels better and better! def one of my favorite mods
More importantly than tires, what is your alignment? If you really want to maximize performance I would suggest -2 up front and -1 in the rear, with 0 toe.
i was actualy wondering that, i had an alignment done after doin top mounts and springs, do i need one again after doin front and rear sways? (27mm front, 24mm rear)
Installation of sways does not affect alignment. Unlike top mounts and springs, installing sways does not require you to change/remove alignment bolts. However, if it has been a while since your last alignment, it couldn't hurt.
sounds good. i may get the alignment redone if i switch springs but who knows, thanks for the info tho!
